Is My Electric Field Curve Exhibiting Exponential Decay?
  • Thread starter Thread starter nordmoon
    Exponential
To determine when the electric field curve starts exhibiting exponential decay, plot the curve on semi-log paper; a straight line indicates exponential behavior. Observing the point where the plot begins to curve signifies the transition from linearity. The R² values, which range from 1.0 to 0.95, indicate the goodness-of-fit, with lower values suggesting a loss of linearity. The key is to identify the point on the plot where the curve deviates from a straight line. This method will help in accurately assessing the behavior of the electric field curve.
nordmoon
I have a curve I obtained in COMSOL representing a electric field for m structure. I have to figure how to determine when the curve starts to become exponential decaying at certain regions.
Any idea how to determine when the curve starts becoming exponential decaying from a plot?
Mathematics news on Phys.org
Plot the curve on semi-log paper. A straight line there will be equivalent to exponential on a linear plot.
How do I see when the plot is no longer linear? I am estimating the curves R2-values (coefficient of determination).
I get values like,
1.0
0.9998
0.9953
0.9915
0.95
etc
I just don't know how to determine when it stops being linear. Do you have any suggestions?
I don't understand your concern. When you plot it and it starts to curve then it is no longer linear.
Low values of R^2 go together with a low (linear) goodness-of-fit .
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
