Is Pentium 4 CPU chip waterproof ?
  • Thread starter Thread starter ramonegumpert
    cpu
Cleaning an old Pentium chip covered in dried thermal paste can be done safely, but caution is necessary to avoid damage. The chip itself is waterproof; however, residual detergent or water can leave corrosive or conductive salts on the pins, which may cause issues. It is recommended to use a hard plastic blade to gently scrape off the thermal paste instead of a knife to prevent scratching. Polishing the surface with fabric like jeans can help achieve a smooth finish. Aerosol contact cleaner is effective for removing residues, and a clean toothbrush can assist with tougher deposits. Isopropyl alcohol (IPA) is also suggested for cleaning, along with careful scraping. The primary concerns during this process are static electricity and bending pins rather than the cleaning method itself.
ramonegumpert
Dear Gurus,
I have an old pentium chip covered with thermal paste that is kind of dried and difficult to remove. I intend to clean it with detergent and water.
Would it still work after it is cleaned and dried? That is , is it waterproof?
Thanks for taking time to read my question.
regards
Ramone
Computer science news on Phys.org
The chip itself is waterproof, the danger is leaving traces of corrosive or conductive salts from the water or detergent on any of the pins after you have dried it.
I would try and clean the thermal goo off with a straight hard plastic blade - don't use a knife you will scratch it.
Then polish the top smooth and clean on your jeans.
PCBs are typically washed at the factory after the components are soldered on. Personally, I wouldn't worry. I think the risk of damage from static electricity or bending a pin would worry me more.
You should be able to find aerosol "contact cleaner" at most places that sell electrical/electronic supplies. Most stuff will come off with a blast of the cleaner, but a cheap toothbrush (clean the bristles with the contact cleaner first) helps loosen the tougher deposits.
Use IPA (isopropyl alcohol) or rubbing alcohol and careful scraping as suggested above.
Dear Experts,
Thank you so much for the advice and explanations.
You guys are great.
Cheers.
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
