Is perpendicularity transitive?
  • Thread starter Thread starter PhysicoRaj
Perpendicularity is not a transitive relation among straight lines, as demonstrated by counterexamples in both two and three dimensions. If line A is perpendicular to line B and line B is perpendicular to line C, line A may not be perpendicular to line C, particularly in a plane where they can be parallel. The discussion highlights that mutual perpendicularity only occurs in specific cases, and the general rule does not hold true without conditions like coplanarity. The use of vectors further illustrates this point, confirming that the transitive property fails in the context of perpendicular lines. Thus, the conclusion is that perpendicularity is not transitive across all lines.
PhysicoRaj
Is perpendicularity transitive??
Is the relation 'perpendicularity' transitive on the set of straight lines? I've been taught 'NO', but I think yes because three mutually perpendicular lines prove the same.
Thanks..
Mathematics news on Phys.org
If perpendicularity is transitive this means that if line a is perpendicular to b and b is perpendicular to c, that this implies a is perpendicular to c for ALL lines a,b,c not only for some lines.
So, mutual perpendicularity is the only case which holds good, and hence the relation is not transitive on the whole. I get it. But is there any condition such as coplanarity mentioned in the rule?
What does "three mutually perpendicular lines prove the same." mean?
If we're talking about lines in the plane (R2), then perpendicularity is NOT transitive. Suppose L1 ##\perp## L2, and that L2 ##\perp## L3. Then clearly, L1 || L3, so transitivity fails.
Lets consider vectors to represent our lines. (in three dimensions)
Let A = [1,0,0], B = [0,1,0], and C = [1,0,0].
Since the dot product of A and B gives us 0, we know that A and B are perpendicular. [1]
Similarly, B and C are perpendicular.
However, the dot product of A and C gives us 1, hence, A and C are not perpendicular.
This counterexample allows us to conclude that the proposition "Perpendicularity is transitive" is false.
[1] http://en.wikipedia.org/wiki/Dot_product#Properties (property 5)This is precisely the same argument that Mark44 used except we fixed the third component at zero. We can further generalize this to n dimensions by fixing components three to n at zero.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
