Is ± Present When Taking 4th Root?
  • Thread starter Thread starter Destroxia
    Root
Taking the fourth root of a number does not inherently include a plus or minus sign, unlike the square root. The principal fourth root of a positive number, such as 16, is positive (e.g., 16^{1/4} = 2). However, there are four fourth roots for any non-zero complex number, including negative numbers, which are spaced evenly around the unit circle in the complex plane. For example, the fourth roots of -1 are 1, i, -1, and -i. Understanding the distinction between principal roots and all possible roots is crucial in complex number calculations.
Destroxia
If you take a 4th root of something, is that answer also plus or minus, just like if you are taking a square root?
Ex. ##4^{\frac 1 2} = ±2##
So following that logic, would that mean that:
##16^{\frac 1 4} = ±2## as well?
Meaning, is the ± still present if you take a 4th root?
While 2 and -2 are square roots of 4, the expression ##\sqrt{4}## denotes the principal (i.e., positive) root, or +2. So ##4^{1/2}## would also be +2.
The principal fourth root of 16 is 2. There are three other fourth roots: -2, 2i, and -2i.
Okay, so I took the 4th root of -1 using a CAS, and ended up getting the result of
## r = \frac {\sqrt(2)} {2} +\frac {\sqrt(2)} {2}i ##
So is there any other answer besides this, or is this the single and only ?
There are four fourth roots, spaced 90° apart (##\pi/2## radians). I don't know if there is a principal fourth root of a negative number, similar to what I said before about the fourth root of 16.
Usually the question is asked as, "Find all of the fourth roots of <N>."
The fourth roots of -1 satisfy the equation ##r^4 = -1## or ##r^4 + 1 = 0##. Since you have a fourth-degree polynomial, there are going to be four solutions.
To find the square roots of 4, you want to solve the equation ##z^2 = 4##. If you express both sides in polar form, with ##z = re^{i\theta}##, you have
$$r^2 e^{i2\theta} = 4e^{i0},$$ which has solution ##r=2## and ##\theta=0##, which corresponds to ##z=2##. But you could also write the righthand side as ##4e^{i2\pi}##, which gives you a second solution, ##r=2## and ##\theta=\pi##, which corresponds to ##z=-2##.
You can use the same method to find all the fourth roots.
Okay, thank you both, I understand how to do this now and have applied it to my problem, but my problem is differential calculus based, so I will post that in the calculus and above section.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
