daz59 said:
Hi,
Is it more efficient to run a heat pump in a house 24/7 or turn it off at night time and during work. All the pros seem to say its more efficient running them 24/7 I can't understand that as there is more heat loss with the greater heat differential running it 24/7
Thanks
Darren
The question is: is it more efficient to leave the heater on 24/7. The question is NOT: is it more convenient or cosy to leave the heater on 24/7. It is a distinction which MUST be kept in mind.
When in doubt, think in extremes!
Is it more efficient leaving your heater on 24/7!
Leave your heater on while walking to the garage and back – certainly!
Leave your heater on while going on holiday – certainly NOT!
So, leaving your heater on while you asleep 7 hrs or at work 10 hrs? the short answer is NO!
It's a myth that leaving the HEATER on while you're away at work uses less energy than turning it on when you get home. Here's why:
Heat goes to where it's not. That's why heat from inside of your house goes (leaks) to the outside, provided the outside temperature is lower than the inside temperature. With the heater off, at some point your house will be as cold as the outside, but no more. When you come home and turn the heater on, the heater removes/heats all that cold air in your house by heating it.
But if the heater is on when you're gone, then you've turned your house into a cold magnet by keeping it artificially warm. There's no limit to the amount of heat which will leak through the windows, doors, ceiling and walls to the outside. Your heater has to replace lost heat constantly. Your heater kicks in and heats some of that cold, then, because the house is warmer than the outside, it leaks more heat to the outside, so your heater kicks in again and heats that cold air again, and so on.
This means that throughout the day, your house has leaked way more than one houseful of cold and your HEATER had to reheat it all. By contrast, with the HEATER off all day, then it has to remove just one houseful of cold air when you come home and turn it on.
Let's say you leave the HEATER off, and your house looses 200kJ or (BTU's if you living in a none-metric country) of heat and then stops, because that's all it can leak to be equal with the outside air temperature. You come home and switch your heater on; all you pay for is 200kJ of energy to heat up your house.
Now let's say that you have the HEATER running instead. The house leaks 50kJ/hr (BTU's) of heat, so the HEATER kicks in and heats the cold air. Then it leaks another 50kJ, and your HEATER kicks in and heats that. Repeat that process say once an hour for 10hrs during the day and 7hrs during the night, you pay for 17x50=850kJ, or 425% more energy than by switching the heater off while you asleep and at work. My heat pump kicks in every 20min during the day to keep my room at 220C and every 30min during the night to keep the temperature at 160C. Go figure, go metric!
The heater start numbers will vary with the daily outside temperature and day and night temperature and the “leakage factor” or insulation quality of your ceiling, walls, doors and windows, Do you have your curtain closed or open, and many other factors. I haven't tested this to see exactly how much the penalty for leaving the HEATER on during the day is, but there is zero question that running the HEATER all the time uses more energy than turning it on when you get home. This is not a gray area, its simple physics, and no person with any knowledge of this subject disputes it. Running the HEATER when you're not home wastes energy, period.
