Discriminant of Quadratic Equations: Difference or Special Case?
In summary: I'm glad I could help.In summary, the discriminant, or determinant, of a quadratic equation is the value D = b^2 - 4ac. The two roots of the equation are x_+ = (-b + sqrt(D)) / 2a and x_- = (-b - sqrt(D)) / 2a, with the difference between them being (x_+ - x_-) = sqrt(D)/a. However, this is not always the case as the condition for the discriminant to be the difference between the two roots is D = sqrt(D)/a or D = 0, D = a^-2. The discriminant only determines the nature of the roots and does not establish any relation between
Sumedh
62
Is the discriminant, of the quadratic equations, the difference between the two roots?
Or is it a special case?
Mathematics news on Phys.org
I'm not sure what your asking here, but the quadratic discriminant is [itex]\Delta = b^2 - 4ac[/itex]. The two roots are
[tex]x_\pm = \frac{-b\pm\sqrt{\Delta}}{2a},[/tex]
with the difference being
[tex]x_+ - x_- = \frac{-b + \sqrt{\Delta} + b +\sqrt{\Delta}}{2a} = \frac{\sqrt{\Delta}}{a}.[/tex]
So in general, the discriminant is not the difference between the two roots. The condition for the discriminant to be the difference between the two roots is
[tex]\Delta = \frac{\sqrt{\Delta}}{a}\text{ or } \Delta = 0\;, \Delta = a^{-2}.[/tex]
The first corresponds to the case when you have repeated roots (obviously) and the second occurs when [itex]a^2b^2 - 4a^3c - 1 = 0[/itex].
Yes Hooteny .
Let x and y be the two distinct roots of quadratic equation ax2+bx+c = 0
and D = b2-4ac then xy (Product of two roots)= c/a and x+y (Sum of two roots) = -b/a .
So we can also write a quadratic equation in this form :
x2+bx/a+c/a = 0
or
A quadratic equation is written in this form :
x2 - (Sum of two roots)x + (Product of two roots) = 0
The only relation which establishes between equal roots of two different quadratic equations are :
c1/a1 = c2/a2 = ... = cn/an
and
-b1/a1 = -b2/a2 = ... = -bn/an
As Hooteny marks :
Difference of two roots of a quadratic equation is : sqrt(D)/a which is not equal to D. Discriminant (D or Δ) or determinant just determines the nature of roots of a quadratic equation.
Thank you very much.
The discriminant of a quadratic equation is a special case that provides information about the nature of the solutions to the equation. It is not simply the difference between the two roots. The discriminant is a value that is calculated from the coefficients of the quadratic equation and can be used to determine whether the equation has two distinct real roots, two complex roots, or one repeated root. It can also indicate whether the roots are rational or irrational numbers. Therefore, the discriminant is an important tool in understanding the behavior of quadratic equations and is not simply a difference between the two roots.
What is the discriminant of a quadratic equation?
The discriminant of a quadratic equation is a value that helps determine the nature of the roots of the equation. It is represented by the symbol Δ and is calculated as b2 - 4ac, where a, b, and c are the coefficients of the quadratic equation in the form ax2 + bx + c = 0.
What does the discriminant tell us about the roots of a quadratic equation?
If the value of the discriminant is positive, the equation has two distinct real roots. If the discriminant is zero, the equation has one real root. And if the discriminant is negative, the equation has two complex (non-real) roots.
Can the discriminant be negative?
Yes, the discriminant can be negative. This indicates that the roots of the quadratic equation are complex (non-real) numbers.
What is the difference between the discriminant and a special case of a quadratic equation?
The discriminant is a value that helps determine the nature of the roots of a quadratic equation. A special case of a quadratic equation refers to a specific form or type of quadratic equation that has unique characteristics. For example, a perfect square trinomial is a special case of a quadratic equation where the discriminant is equal to zero.
How is the discriminant used in solving quadratic equations?
The discriminant can be used to determine the number and nature of the roots of a quadratic equation, which can then be used to solve the equation. If the discriminant is positive, the equation can be solved using the quadratic formula. If the discriminant is zero, the equation can be solved by taking the square root of both sides. And if the discriminant is negative, the equation can be solved using complex numbers.
  • General Math
  • General Math
  • General Math
  • General Math
