I know that the power of an engine is equal to (rpm*torque)/ 9.54 (SI
units). But does this mean that an engine when turned on is outputting the same amount of energy per unit time
This is the actual power output at one particular time. If you change the torque or the rpm, then obviously the power changes.
What happens when we press the gas pedal, does the power output increases?
The car goes faster, so the rpm increases and the torque must have increased to cause that acceleration. So power increases on both counts.
In the case of the engine my intuition tells me that the energy output does change, but when i try to reconcile my intuition with my knowledge of physics i don't see how that can be, it must remain constant.
Why must power remain constant? When the car is sitting in the garage, it outputs no power. When you start and it ticks over it outputs just enough to overcome engine "friction". When you load up the family and luggage and attach a camper van, then accelerate hard, it must be putting out a lot of power. I just can't imagine what knowledge of physics is predicting otherwise? I think your intuition seems to be a better guide.
So if an engine has 120 kW of power. That doesn t mean the engine will be using 1000 j per second, every time?Does the relation between power torque and rpm still hold, when the engine is not operating at full power?
I think this is the clue! If you have a 120kW engine (lucky you, mine is only 40kW) then the manufacturer is claiming that you can get it to output this much power - it is the maximum, you cannot get more. Most of the time, nearly all of the time, it will be producing much less than this.
The relation between power, torque and speed is always true, but the torque and speed vary, so the power varies.
... running or walking. The only force we are subjected to is gravity, and gravity does no work on us since we don't move in the y direction,
Actually we do: we bob up and down a bit. In the case of running, when you may be out of touch with the ground between footfalls, this is more obvious than in walking.
and therefor if there is no dissipative forces to overcome we wouldn't need to do any work. But in reality we do work, and i guess i do more if when i run than when i walk. Can someone help me to understand this?
Even if we do no work against outside forces, we move our limbs causing internal "friction" using inefficient muscles, pumping blood and air, etc. As for the vertical bobbing, we do work lifting ourselves each step, but do not recover all of that energy when gravity pulls us back down - in fact we have to do yet more muscular movement to cushion the impact.
I don't know if you do more work running than walking, but you do it in a shorter time, so the power is greater. It is conceivable that running could be more efficient than walking. I think I feel more tired after going for a walk with my partner, who is very slow, than if I walk a similar distance more quickly on my own, but there are many confounding issues there.
two blocks on a frictionless surface, both weight the same. The first covers 100 meters in 6,66 seconds the second does it in 20 seconds. Which block needs more work?
Other posters comments are agreed.
Assuming you apply a constant force, then you are doing work to accelerate the blocks and the one that gets there first must have greater acceleration.
a = 2xdist/time
2 so one block a= 200/ 6.6
2 = 4.6m/sec
2 other a= 200/400 = 0.5 m/sec
So the faster one has 9.2x the acceleration, so needs 9.2x the force.
Work = force x dist, so faster block needs 9.2x the work, done in shorter time 6.6/20.
So average power for faster block is abot 27.8x the av. power for slower block.
For constant force, accn is constant, so speed increases linearly and so does rate of doing work. So power is increasing linearly.
When you stop pushing both blocks continue at constant speed, one being about 3x faster than the other and having 9.2x the KE than the other.
I think that however you accelerate the blocks, even with a varying force, you will always need to do more work and apply greater average power on the block that gets there faster and that will be reflected in a faster speed and greater KE for that block.
