Is the Given Solution for S(T,V) of an Ideal Gas Accurate?
DRose87
Given: Ideal gas equations:
Find S(T,V) for an ideal gas
\begin{array}{l}<br /> {\rm{}}\\<br /> U = \frac{3}{2}N{k_B}{\left( {\frac{N}{V}} \right)^{2/3}}\exp \left[ {\frac{S}{{\left( {3/2} \right)N{k_B}}} - {s_0}} \right]{\rm{ }}\\<br /> T = {\left( {\frac{{\partial U}}{{\partial S}}} \right)_{V,N}} = \frac{U}{{\left( {3/2} \right)N{k_B}}}\\<br /> \\<br /> {\rm{Find: }}\\<br /> {\rm{S = S}}\left( {T,V} \right){\rm{ }}\\<br /> \\\end{array} for an ideal gas
The answer, according to the book (David Goodstein's new book "Thermal Physics: Energy and Entropy")
S = \frac{2}{3}N{k_B}\log T{\left( {\frac{V}{N}} \right)^{2/3}} + {s_0} = S\left( {T,V} \right)
I'm not sure if the answer given in the book is correct and I'm missing something, or if it is an error.
\begin{array}{l}<br /> \\<br /> U = \frac{3}{2}N{k_B}{\left( {\frac{N}{V}} \right)^{2/3}}\exp \left[ {\frac{S}{{\left( {3/2} \right)N{k_B}}} - {s_0}} \right]{\rm{ }}\\<br /> T = {\left( {\frac{{\partial U}}{{\partial S}}} \right)_{V,N}} = \frac{U}{{\left( {3/2} \right)N{k_B}}} = \frac{{\frac{3}{2}N{k_B}{{\left( {\frac{N}{V}} \right)}^{2/3}}\exp \left[ {\frac{S}{{\left( {3/2} \right)N{k_B}}} - {s_0}} \right]}}{{\frac{3}{2}N{k_B}}}\\<br /> = {\left( {\frac{N}{V}} \right)^{2/3}}\exp \left[ {\frac{S}{{\left( {3/2} \right)N{k_B}}} - {s_0}} \right]\\<br /> \exp \left[ {\frac{S}{{\left( {3/2} \right)N{k_B}}} - {s_0}} \right] = \frac{T}{{{{\left( {\frac{N}{V}} \right)}^{2/3}}}} = T{\left( {\frac{V}{N}} \right)^{2/3}}\\<br /> \frac{S}{{\left( {3/2} \right)N{k_B}}} - {s_0} = \log \left[ {T{{\left( {\frac{V}{N}} \right)}^{2/3}}} \right]\\<br /> \frac{S}{{\left( {3/2} \right)N{k_B}}} = \log \left[ {T{{\left( {\frac{V}{N}} \right)}^{2/3}}} \right] + {s_0}\\<br /> S = \frac{3}{2}N{k_B}\log \left[ {T{{\left( {\frac{V}{N}} \right)}^{2/3}}} \right] + \frac{3}{2}N{k_B}{s_0}\\<br /> \\<br /> \\<br /> <br /> \end{array}
Book is a typo.
I like David Stroud's treatment https://www.physics.ohio-state.edu/~stroud/p846/idealgas.pdf (more https://www.physics.ohio-state.edu/~stroud/p846/p846notes3.pdf, etc.)
Likes DRose87
Thanks BvU and robphy for your opinions and the links you both postsed. I agree that it is a typo. It is kind of funny that this is actually the first problem in the book and there is a typo. I hope that the rest of the book isn't plagued by errors... fortunately if that turns out to be the case, my class is using a different book, Classical Statistical Thermodynamics by Ashley Carter.
Goodstein has a mail address; I'm sure he'll appreciate if you point out stuff he can improve for the next edition !
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
