Is the Higgs Field a New Perspective on Gravity Beyond General Relativity?
ohwilleke
Higgs hypothesized that mass derives from the coupling constant of various particles with the Higgs Boson, a spin zero boson, which would itself have mass, which does not couple with the photon. Thus, inertial mass derives from particles in motion needed to overcome Higgs Bosons grabbing at them slowing them down from the default rate of movement in the absence of these couplings which is c.
The proposed graviton, which would be a spin two Boson which interacts with photons, would then be a particle creating a force to drag other particles through the Higgs field just like any other force.
My questions: Is the Higgs field an alternative to the curvature of space description of gravity described by GR or in a QM interpretation with a Higgs Field and a Graviton does this apparent curvature derive from the field equations associated with the Graviton?
When symmetry is spontaneously broken, the vacuum state is not the lowest energy state. You "shift" the fields using a gauge transformation so that the new fields do have the vacuum state the lowest. This involves incorporating the Higgs field to achieve this. The new equations have a mass term appearing. i.e. the "shift" causes the energy to go from the vacuum to the particle. (my interpretation only.)
The curvature of space-time in GR is, as I understand, completely unrelated and therein lies the big problem. I wish I knew how to fix this "patch"!
Higgs particles can be like black holes in Quantum Gravity - no?
Can't you just see it at the LHC?
Oooooh - nice little black holes. Now
where are those Higgs particles? :confused:
Hi,
From what I know, the Higgs field and the curvature of space are not alternative descriptions.
The Higgs field describes why particles (mass) need a force to be moved through space (= space is "something") and that an acceleration of a particle can be measured against space itself (not only against other particles, see also SRT).
Chronos said:
It is more accurate to think of gravity as an allergic reaction by space to the presence of matter [space curves around it].
A mass particle experiences both at the same time: the curvature of space was well as the Higgs field. The acceleration principles of the SRT (here: Higgs field) apply also under the GRT which comprehends gravitation.
Take care,
Carsten
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
