Is the Inverse of f(x) a Function?
  • Thread starter Thread starter aisha
    Function Inverse
The discussion centers on determining whether the inverse of the function f(x) = 5√(x+1) + 2, defined for x ≥ -1, is a function. The restriction x ≥ -1 ensures the square root is defined. To find the inverse, one must square both sides of the equation after isolating the square root. It is established that the function is strictly increasing, which confirms that its inverse is also a function. The vertical line test is mentioned as a method to verify if a relation is a function, emphasizing that each x-value corresponds to only one y-value in the inverse.
aisha
f(x)=5*the square root of (x+1) +2 x>=-1
determine if the inverse is a function.
I don't understand y are they telling me x>=-1? Also I know how to find the inverse but what do I do to each side of the equation to get rid of the square root? ^2? I got the inverse= [x^(2)-1]/25 I don't think this is right. How do u do this question? :confused: :cry:
f(x)=5\sqrt{x+1}+2, x>=-1
The square root is only defined if the number in the root is >=0. Since x+1>=0, x>=-1.
To get rid of the square root, square both sides
To find the inverse:
y=5\sqrt{x+1}+2
y-2=5\sqrt{x+1}
(y-2)^2=(5\sqrt{x+1})^2
(y-2)^2=25(x+1)
x=\frac{(y-2)^2}{25}-1
f^{-1}(x)=\frac{(x-2)^2}{25}-1
y=5\sqrt{x+1}+2
y-2=5\sqrt{x+1}
(y-2)^2=25(x+1)
THANKS SOOOO MUCH I GET IT TOTALLY
How do u find out if the inverse is a function?
A relation between a dependant and an independant variable is said to be a function if to each value taken by the independant variable, the dependant variable takes one and only one value.
There is a theorem that you can use that allows you to answer the question without even having to find the inverse: If a function has an interval for a domain and if it is strictly increasing, it has an inverse (i.e. the inverse is a function).
You are given the domain of your function: it is all numbers x such that x\geq -1. That's an interval. It's the interval [-1, +\infty[. So all you need to do is show that the function is strictly increasing. That is to say, we must show that for any two distinct points of the domain, say x_1 and x_2 such that x_1 < x_2, the two corresponding images of these two points by the function f are such that f(x_1) < f(x_2).
This is not hard to do. I'll do your problem as an exemple.
Consider x_1, x_2 two points of the domain such that x_1 < x_2. This inequality implies that f(x_1) < f(x_2) iff (if and only if, noted \Leftrightarrow)
5\sqrt{x_1+1}+2 < 5\sqrt{x_2+1}+2 \Leftrightarrow 5\sqrt{x_1+1} < 5\sqrt{x_2+1} \Leftrightarrow \sqrt{x_1+1} < \sqrt{x_2+1} \Leftrightarrow x_1+1 < x_2+1 \Leftrightarrow x_1 < x_2
,which we have supposed to be true. Therefor our proposition according to which x_1 < x_2 implies f(x_1) < f(x_2) is true. So our function is stricly increasing and according to the theorem, the inverse is a function.
Or, if you know calculus, you can show that a function is strictly increasing by showing that the derivative is positive everywhere on the domain.
A particular relation is a function, if for an element in the domain, there is only one element in the range. Or in other words, for a particular x value, you only get 1 y.
For example:
y=3x+1 is a function because when you plug in an x value, you only get 1 y.
On the other hand
y=\pm\sqrt{x}, where\ x\geq 0
is not a function because, for a positive x you get 2 y values.
This is also called the vertical line test... If you plot your relation, and any vertical line you can draw intersects your plot at at most one point... then it's a function. If there's a vertical line you can draw that intersects your graph at two or more points then it's not a function.
The inverse relation in your problem is a function becuase you only get one y when you plug in an x value.
Hey guys thanks sooo much I understand now. :smile:
