Does This Sequence Converge to 2?
  • Thread starter Thread starter Punkyc7
    Limit Sequence
Punkyc7
use the definition of a sequence to establish the limit
lim(\frac{2n}{n+1})=2 Let \epsilon>0, then |\frac{2n}{n+1}-2| <\epsilon. Next we have that | \frac{2n-2n+-2}{n+1}|= |\frac{-2}{n+1}| <\frac{2}{n}. So \exists k\inN such that \frac{2}{k}<\epsilon. When n\geqk, we have \frac{2}{n} < \frac{2}{k} <\epsilon. Therefore the limit is 2. BLOCKIs this the right way to do a limit proof?
Looks good. Some remarks:
2n+-2 is not something one writes. You'll have to write 2n+(-2) or simply 2n-2. I think you've just made a typo, but I wanted to make sure.
Why does such a k exist?
The Archimedean property right, is that something I should mention? Another question if we weren't given what the limit is equal to do you just make a guess and see if it right?
Yes, you should certainly mention that!
Yes, you need to make an educated guess by looking at the graph or perhaps by using properties of the limit. But I'm sure you will see some easy ways to calculate limits soon.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
