- #71
- 14,265
- 6,744
It's true, that's a standard method in crystallography. That's also how the shape of DNA was discovered.fanieh said:Is it really true the interference pattern of the screen is the Fourier transform of the slits?
Demystifier said:It's true, that's a standard method in crystallography.
I think, the string theorists are neither physicists (no interest in making predictions that can be empirically tested) nor mathematicians (lack of rigor). SCNR.Demystifier said:Mathematicians would probably disagree, but I guess you think the same about string theorists.
I wouldn't say it's another apple in the inverse spacetime. I would say it's just another representation of the same apple.fanieh said:I just ordered the book Atlas of Optical Transforms this morning to see the other drawings because he got it from the Atlas book.
But he was suggesting that every object has a real momentum space counterpart.. so pilot wave of a particle is connected to the inverse spacetime. He said just as we have apples in our physical universe.. there is another apple in the inverse spacetime... and the two are coupled by something. In his experiments.. He can adjust the coupling such that he can make the thermodynamics of this physical spacetime be connected to the inverse spacetime so all his experiments show oscillations and that's how he concluded there was a real reciprocal spacetime. Are you saying this is also true? If not true, why not true?
Demystifier said:I wouldn't say it's another apple in the inverse spacetime. I would say it's just another representation of the same apple.
I you are not too young, you have probably seen a negative of a photography, in which all colors are inverted. But it does not mean that there is another inverted you in an inverted universe. The above is similar.
So Bohmians are more rigorous than string theorists? Tell it to Lubos Motl!vanhees71 said:I think, the string theorists are neither physicists (no interest in making predictions that can be empirically tested) nor mathematicians (lack of rigor). SCNR.
I guess it means that, in reciprocal space, electric charges look like magnetic monopoles. The emphasis is on look like.fanieh said:Thanks I got it now what is the conventional idea of this reciprocal space. He was also suggesting magnetic monopoles are located in this actual reciprocal space and he can make magnetic monopoles appear in his experiments. I think this is the part that is not true.
There cannot be a strict separation between physics and mathematics, but there must be a strict separation between physics and philosophy to make any progress in either of these fields.Demystifier said:Now more seriously. I don't think that there should be strict separation between physics, mathematics, philosophy, etc. It is perfectly natural and healthy to have interdisciplinary research which combines some (but not all) features of two or more fields. For instance, string theory combines some features of physics and mathematics; quantum foundations combines some features of physics, mathematics and philosophy, etc.
Demystifier said:I guess it means that, in reciprocal space, electric charges look like magnetic monopoles. The emphasis is on look like.
Why do you think that philosophy cannot make progress by using insights from physics?vanhees71 said:there must be a strict separation between physics and philosophy to make any progress in either of these fields.
In the simplest minimal version of dBB, you are right. But other versions are explored too.vanhees71 said:I still don't know, whether I'm wrong in my claim that according to dBB the trajectories in configuration space are considered as unobservable (or "hidden") or not.
It's unnecessary only if you don't think that there is the problem of measurement.vanhees71 said:If so, dBB is just the same as QT in its testable predictions and thus merely an interpretation with IMHO unnecessary complications.
Bohmian trajectories are not only an interpretation, but also a practical tool. There are many cases in which calculation of trajectories actually helps to make measurable predictions.vanhees71 said:To calculate unobservable trajectories which don't help in predicting anything observable is just pointless from a physicist's point of view. It's maybe a nice mathematical exercise for bored QM students.
fanieh said:btw.. let me emphasize my questions:
Are you saying that if your perform Fourier transform of the 2 dots above.. it will produce the interference patterns at the bottom even without any light or electron passing thru the slits?
See the reply by @vanhees71 above.fanieh said:Are you saying that if your perform Fourier transform of the 2 dots above.. it will produce the interference patterns at the bottom even without any light or electron passing thru the slits?
vanhees71 said:If nothing goes through the slits, you don't see any interference pattern. I think about this triviality even non-minimalistic philosophers agree. You cannot get an interference pattern by calculating a Fourier integral. The latter predicts the interference pattern in Fraunhofer observation based on some theory with wave equations (e.g., classical electrodynamics).
Noooo, it wouldn't be you!vanhees71 said:Ok, perhaps I should give dBB a chance again and learn the details about it...
The book by Dürr contains some rigorous mathematics (if this is what you want), but it does not discuss real applications.vanhees71 said:Yes, pure science would be good, but isn't that textbook by Dürr good? I could omit the philosophy introduction easily ;-)).
Demystifier said:See the reply by @vanhees71 above.
Demystifier said:@fanieh you didn't tell us the author and title of the book you are referring to.
