Is the Self Inductance of the Hairpin Loop Calculated Correctly?
stunner5000pt
Griffiths problem 7.23
Copute the self inducatnce of the hairpin loop shown in the figure. (neglect contribution from ends since mosto f the flux comes form the straight section) To get a definite answer , assume the wire has a tiny radius epsilon, and ignore any flux through the wire itself
\Phi = LI
L = self inductance and I is the current through the loop
induced emf is
\epsilon = - L \frac{dI}{dt}
ok the flux due to straight part on top is (and its legnth is l)
\Phi = \frac{\mu_{0} Il}{2 \pi} \int_{\epsilon}^{d} \frac{dr}{r} = \frac{\mu_{0} Il}{2 \pi} \ln \frac{d}{\epsilon}
due to the bottom wire has the same value
so the total flux is
\Phi = \frac{\mu_{0} Il}{\pi} \ln \frac{d}{\epsilon}
now the self indutance is then
L= \frac{\mu_{0} l}{2 \pi} \ln \frac{d}{\epsilon}
is this correct??
Thanks for the help!
Almost. You have a magical 1/2 that shows up in your expression for L that shouldn't be there.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
