Is the Work Done in Charging an Inductor Different in Non-Quasistatic Scenarios?
The discussion revolves around the work done in charging an inductor, particularly focusing on whether this work differs in non-quasistatic scenarios compared to quasistatic approximations. Participants explore the implications of charging rates and the potential for energy loss due to radiation in various contexts, including DC and AC sources.
  • One participant asserts that the work done in charging an inductor, denoted as W, may be greater than 1/2LI² in non-quasistatic scenarios, questioning if W approaches 1/2LI² as the charging time T approaches infinity.
  • Another participant confirms that the equation E=(1/2)LI² is valid under the assumption that no energy is radiated away, but acknowledges that radiation could lead to energy loss not accounted for in basic equations.
  • There is a discussion about the existence of lossless LC circuits, with one participant questioning how they can exist if radiation occurs due to current flow, while another clarifies that LC circuits are not completely lossless and that losses can be both resistive and radiative.
  • A participant suggests that charging the inductor from a DC source may result in zero radiated energy, as EM radiation typically requires alternating current.
  • Another participant emphasizes that EM radiation is associated with alternating current, indicating that using a DC supply would not produce such radiation.
Participants express differing views on the implications of non-quasistatic scenarios and the nature of energy loss in inductors. There is no consensus on whether the work done in charging an inductor is definitively greater than 1/2LI² in non-quasistatic conditions, nor on the characterization of LC circuits as lossless.
Participants note that assumptions about radiation and energy loss depend on the type of current (DC vs. AC) and the quality factor of the circuit, which complicates the discussion of energy conservation in inductors.
mayank pathak
As we know, work done by an outside agency in creating some current ''I" in an inductor 'L' is 1/2LI2. Now this result is derived by quasistatic approximation if I am not wrong. Now, I am assuming that in non quasistatic (real) scenarios, the work done by outside agency would be different(If you actually calculate by using Poynting Vector, there would be some radiation flying off ...). Am I right till here ?
My question is :Let W be the work done in charging inductor to current I in time T (at a rate of I/T amperes per second) without making qusi static approximations. Is W > 1/2LI2 ? Also, if T approaches infinity (i.e. the rate of increasing current is too darned slow), will W approach 1/2LI2 ?
<< Post edited by Mentor for language >>
To help answer your question ## L=\frac{\Phi}{I} ## , and for a long cylinder ## B=n \mu_o I ##. The result is with ## E=(1/2)LI^2 ## and with ## \Phi=nL( BA) ## that ## E=(1/2) \frac{B^2}{\mu_o} V ##. This assumes nothing gets radiated away=otherwise, yes, there is power that is lost and not described by these basic equations. It is still correct that ## E=(1/2) LI^2 ##. That part of the energy is recoverable.
Yes. Thanks. I think I get it now.
Also, is my assumption about super-slow process true(will W= 1/2LI^2 in that limiting case where T approaches infinity)
Yes
Khashishi said:
Yes
One more question : then how can an lossless LC circuit exist ? It should lose energy by means of radiation since current in the circuit is definitely greater than zero(hence quasistatic approximation certainly doesnot hold)
I don't know that anyone ever said that an LC circuit is completely lossless. Normally, LC circuits come with a quality factor ## Q ##, and the higher the ## Q ##, the smaller the losses. The losses can be both resistive and radiative, and it can be somewhat difficult to determine how much is resistive and how much is radiative.
Thanks. "Lossless" word stuck with me and I guess I never cared so deeply about these questions until now. Maxwell equations has certainly enlightened me. I almost see the whole picture now. Thanks again :)
It sounds as if you are charging the inductor from a DC source such as a battery.
Any EM wave radiated would then have to be unidirectional. The usual view is that this is not possible.
So it looks as if the radiated energy may be zero for this case.
I didn't understand. Can you elaborate more ?
In order to obtain EM radiation, we require an alternating current. You are using a DC supply so there is no alternating current.
If the inductor is connected to AC, then there will be some radiated energy, depending on the dimensions and the size of the current.
  • · Replies 83 ·
18K
