Is there a non-geometic proof of this inequality
  • Thread starter Thread starter Mu naught
    Inequality Proof
Mu naught
sinx ≤ x ≤ tanx
You need the above inequality to prove that lim x-> 0 of sinx/x = 1, but I've only ever seen it derived geometrically. Is there an analytical proof of the above inequality, from which you can continue the sinx/x proof as normal?
Mathematics news on Phys.org
that limit is elegantly proved using the series definition of the sin function. no need for that inequality.
As tauon suggests, it depends upon how you define the trig functions. You can define sine and cosine in terms of their McLaurin series (lots of fun proving periodicity from that!). You can also define "y= sin(x)" as the solution to the differential equation y"= -y with y(0)= 0, y'(0)= 1, and define "y= cos(x)" as the solution to the differential equation y"= -y with y(0)= 1, y'(0)= 0.
In either case, you don't need that inequality nor that limit to derive the derivatives of sine and cosine.
All the horrible, horrible memories. None of it even came up in the Analysis paper. If you just want the inequalities, without being too fussy about "how much we know" at this point:
Integrate cosx<1 for the first bit.
Integrate 1<(1/cos^2 x) for the second bit.
(We have to assume we know the derivatives of trig functions, and a few properties of integration. From the proofs involved, we probably know enough to do the sinx/x anyway, but...there it is if you need to check the result in an exam or something).
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
