I Is there a problem with this set of plots?
  • I
  • Thread starter Thread starter Spinnor
    Plots Set
The discussion centers on a graphic from a May 2004 Physics Today article regarding light's orbital angular momentum. Observers note that as the angular momentum quantum number l increases, the "hole" in the beam depicted in the second column enlarges, while the "hole" in the third column appears to remain constant in size. However, measurements indicate that the holes in the third column do actually increase with larger l values. This raises questions about the expected behavior of the holes in relation to the angular momentum. The conversation highlights the complexities of visualizing light's properties in relation to its angular momentum.
Spinnor
Consider a graphic from May 2004 Physics Today article, Light's orbital angular momentum.
Note that for larger l, the "hole" in the beam in the 2nd column gets bigger but the "hole" in the 3rd column basically stays the same size. I would think that both "holes" should grow with increasing l?
Thanks!
If you measure the holes in the 3rd column they do seem to get bigger.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
