Is there a way to disrupt air molecules?
  • Level: Undergrad
  • Thread starter Thread starter frozenguy
    Air Molecules
6 replies · 5K views
frozenguy
I want to know if there is a way to push or disrupt air molecules around an object, or the device. Like some time of electrical field maybe?
How would one attempt to go about creating a space evacuated of air around the device, with a field, or a vacuum nearing evacuation.
You would pretty much have a force-field if you did that, I don't think there is any way to do that reasonably.
What do you mean by a force-field? Don't generate fields with electromagnetics? Those have forces.
Well can someone point me in the direction of where one could start?
How can you manipulate gaseous molecules of N, and O?
More importantly, how would one measure a result like this? You could have tubes at different heights off the surface of the device that ran to barometer's.
Actually, just use this "http://en.wikipedia.org/wiki/Plasma_window" and your set. It is a force field for all intents and purposes!
Well, I'm thinking more along the lines of just repelling the gaseous atoms away from the device, in all directions. Like a short distance, x. a few cm, half a meter, I dunno.
The plasma window is interesting but it has plasma on the outside which I don't think I want in this experiment.
Yeah, you wouldn't want to hold it for too long.
If you need a device that repels air strongly enough to hold a good vacuum while not repelling your hand at all your going to need to do some research for a while.
The ideas being talked about here are just not possible with current technology.
Vacuums can be created inside rigid-walled vessels, but there is no way to just repel air molecules and create a vacuum in mid-air, so to speak.
