Is there an analytical way to get average energy of a Fermi-Dirac gas?
seflyer
The average particle energy of a Fermi-Dirac gas, with zero chemical potential, is about 3.15T, where T is the temperture of this gas. To get the average energy, one needs to do an integration. The integrand is something like
\frac{x^3}{e^{x/k_BT}+1}.
I could get the result numerically. But is there a way to do it analytically? Thanks.
[updated] Sorry. The expression is corrected now. So basically I would like to know whether the following can be integrated analytically:
\int_0^\infty \frac{x^3}{e^{x/k_BT}+1} dx
Erm, it's been a while since I have done thermal physics, so correct me if I'm wrong, but I think
$$\langle E \rangle = \int \varepsilon f(\varepsilon) g(\varepsilon) \, \mathrm d\varepsilon$$
where
$$f(\varepsilon) = \frac{1}{e^{E/k_B T} + 1}$$
I'm not sure what g is anymore, I just Googled and found ##g(\varepsilon) \propto \varepsilon^{1/2}##. This would give
$$\langle E \rangle = \int \frac{\varepsilon^{3/2}}{\exp(\varepsilon / k_B T) + 1} \, \mathrm d\varepsilon$$
which is like your expression but with ##x = E = \varepsilon##.
In short, I'm not sure you have posted the correct integral so maybe you can post the exact integral you are trying to do.
where
To CompuChip: Thanks. Now I've corrected the expression ( Not exactly like yours. ) The question is more clear now.
Hmm, a cubic? Interesting.
I asked Wolfram Alpha and it says that the integral can be done, but it involves some ugly polylog functions.
I think you would have better luck trying contour integration. You can get rid of the constant:
$$I = \int_0^\infty \frac{x^3}{\exp(x) + 1} \, dx$$
which has a pole at ##x = i\pi##. I haven't done contour integrals in a while so I would have to work this out, but usually you would integrate over a quarter circle with radius R and then down the imaginary axis, going around the pole. Putting in the integration boundaries in Wolfram Alpha gives a nice answer involving pi, so this is probably going to work :)
Would that help you?
PS I also found this page which does not help you in this case, but I thought the trick was cool so I'd share it.
Hmm, actually the "nice" result of ##\pi^2/12## was for x/(exp(x) + 1), so the "linear" variant. I have to leave now, but maybe you can work that out by hand and see if you can generalize to higher powers, either by doing the same computation, or by some differentiation trick.
$$\int_0^\infty \frac{x^n}{e^x+ 1} dx = (1-2^{-n})\,\Gamma(n{+}1)\,\zeta(n{+}1)$$
for n>-1, where Γ is the Euler gamma function and ζ is the Riemann zeta function.
Likes 1 person
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
