Is there an inverse Z transform for: 1/z-1 ?
The inverse Z transform for the function 1/(z-1) can be derived using two approaches: the Laurent Series for |z|>1 and the Taylor Series for |z|<1. For the casual sequence, the Z transform yields a[k] = u[k-1], while for the anti-casual sequence, it results in a[k] = -u[-k]. This discussion clarifies that the inverse Z transform does exist, despite initial confusion regarding its presence in standard tables.
  • Understanding of Z transforms and their properties
  • Familiarity with Laurent and Taylor series
  • Knowledge of unit step functions (u[k])
  • Basic concepts of signal processing
  • Study the properties of Z transforms in detail
  • Learn about Laurent Series and their applications in signal processing
  • Explore Taylor Series and their significance in function approximation
  • Investigate the role of unit step functions in discrete-time signals
Students and professionals in electrical engineering, signal processing, and applied mathematics who are working with Z transforms and discrete-time systems.
LM741
hay guys -really struggling to find an inverse Z transform for: 1/(z-1)
doesn't seem to exist in the table of z transforms - so is this in fact possible to invert?? In case you're wondering - this forms part of a tut question.
thanks
John
thanks
John
I'm wondering about something similar. I plotted some points in the transformation and it seems to be a circle but I can't manipulate it to get it in a form where I could find the radius or center.
For a casual sequence it will be a Laurent Series: |z|>1
[tex]\frac{1}{z-1}=\frac{1}{z}\frac{1}{1-1/z}=\frac{1}{z}\sum^{\infty}_{k=0}z^{-k}=\sum^{\infty}_{k=1}z^{-k}[/tex]
Then by recalling the definition of the Z Transform:
[tex]a[k \leq 0]=0[/tex]
[tex]a[k \geq 1]=1[/tex]
Or using the step signal it's a[k]=u[k-1].
For an anti-casual sequence it will be a simple Taylor Series: |z|<1
[tex]\frac{1}{z-1}=-\sum^{\infty}_{k=0}z^{k}[/tex]
So
[tex]a[k \geq 1]=0[/tex]
[tex]a[k \leq 0]=-1[/tex]
Or a[k]=-u[-k]
  • · Replies 18 ·
