Is there any smart material that gets lighter/heavier?
  • Context: Undergrad
  • Thread starter Thread starter WakaShocka
    Material
The discussion revolves around the concept of smart materials that can change their weight or density in response to external stimuli, such as electrical current or temperature changes. Participants explore theoretical and practical implications of such materials, including potential applications and limitations.
  • One participant suggests that changes in size or density, possibly through programmable matter, could allow for weight changes, but notes a lack of existing information on this topic.
  • Another participant proposes using a solenoid or memory metal to achieve changes in volume, which could indirectly affect weight.
  • Hot air balloons are mentioned as an example of materials that can change buoyancy, though not weight in the traditional sense.
  • Concerns are raised about the feasibility of changing weight without violating the law of conservation of mass, with one participant stating that what is desired cannot be done.
  • A participant questions the possibility of a mechanism that translates energy to mass, referencing Einstein's equation E=mc² and the immense energy required to change mass significantly.
  • Humorous suggestions are made regarding extreme measures, such as "smashing the sun" to generate energy, which leads to a discussion about the impracticalities of such ideas.
Participants express differing views on the feasibility of changing weight through smart materials. While some explore theoretical possibilities, others assert that such changes would violate fundamental physical laws. The discussion remains unresolved, with no consensus on a viable solution or approach.
Participants acknowledge the limitations of their ideas, including the need for more context and specific applications to provide realistic solutions. The discussion also highlights the dependence on definitions of weight and mass in the context of proposed mechanisms.
WakaShocka
Hi PF,
This could possibly be through a change in size or density...Maybe even programmable matter. I've tried some googling but haven't found anything on actually changing the weight through putting a current through something. It would be extremely useful for my personal hobby. Even through a change in temperature, not necessarily a current would maybe be acceptable. It doesn't have to be anything too big, just a few millimeters/centimeters in size, but some sort of material or substance that can change its weight (preferably without expanding too much, but that would still be interesting to) when a current runs through it or the temp changes..
If you guys have heard of anything like this, let me know!
Science news on Phys.org
WakaShocka said:
Hi PF,
You could use a solenoid to increase or decrease the volume of an enclosure, or you could use memory metal to do a similar thing. What is the application?
https://en.wikipedia.org/wiki/Shape-memory_alloy
:smile:
WakaShocka said:
Hi PF,
Hot air balloons.
What is the application? :smile:
I'm looking to have some sort of material that I can make lighter/heavier on demand to create a weight imbalance in my device (it isn't very large-no more than a few centimeters).
Many materials change density with current (eg a lightbulb filament) but changing weight would break the law of conservation of mass.
https://en.m.wikipedia.org/wiki/Conservation_of_mass
What you want can't be done.
If you explain exactly what you are trying to do (with diagrams perhaps) and why, we may have more realistic solutions.
Kind of like one of these sipping bird toys?
https://s3.amazonaws.com/cdn.teachersource.com/images/products/pop/db100.jpg
Or are you working on an Over-Unity Energy Generation Mechanism?
but what about a mechanism that translates energy to mass?? wouldn't that work somehow?
E=mc2 is a well known formula. You would need a heck of a lot of energy to change the mass by 1gram. (1014 joules)
Unfortunately, without some more context, this thread can go nowhere.
lets smash the sun then
If the objective is to generate energy, then there are unavoidable costs involved with shipping the energy up from the sun. Or exploited for a net gain when that energy is moved about within the Earth's gravitational well.
If you can blow up the sun, powering a dipping bird may not be high on your list of tasks remaining to be accomplished.
You may be better served creating a small black hole and harvesting energy as you drop breadcrumbs in. Be careful how big you make it. If you start at 1,000 metric tons, Hawking evaporation will take only 46 seconds. This is like 2 million Hiroshima sized bombs going off per second for 46 seconds.
https://www.vttoth.com/CMS/physics-notes/311-hawking-radiation-calculator
You are going to need to drop breadcrumbs in at [very roughly] 20 metric tons per second just to break even and keep the debacle from getting worse.
Things get a bit easier if you start at 1,000,000 metric tons. Then you have about 1400 years to add another 1,000,000 metric tons and keep things stable.
Welcome to PF, @Mrdoupi
Please try to avoid resurrecting years-old threads with whimsical thoughts. This old thread is now tied off with the helpful reply by @jbriggs444
  • · Replies 28 ·
  • · Replies 69 ·
