Zero Gravity: ISS Orbit & Neil Degrasse Tyson
  • Thread starter Thread starter kghosh
    Gravity Zero
The discussion clarifies that the term "zero gravity" is misleading when describing the environment of the International Space Station (ISS), which is actually in free fall, creating a sensation of weightlessness for astronauts. Despite the term, gravitational forces are still present, enabling the ISS to maintain its orbit around Earth. The confusion arises because "zero gravity" refers to the absence of normal force felt by astronauts, not the absence of gravitational force itself. Neil Degrasse Tyson's comments on bone loss in space relate to this weightlessness, highlighting the physiological effects of living in a low-gravity environment. Ultimately, understanding the distinction between gravity and the sensation of weightlessness is crucial for comprehending the conditions in space.
kghosh
I read in a physics textbook that it is not zero gravity in ISS but the fact that the ISS is in "free fall" makes astronauts float around. They do not feel any normal force because the vehicle they are in are also in free fall along with them. Then I watched Neil Degrasse Tyson talk about bone loss in ISS because astronauts are in zero gravity. If it is zero gravity then why is the ISS in orbit? There should be no centripetal force to keep it in orbit. I am confused!
The term 'zero gravity' is often used when referring to things in free fall.
It is inaccurate.
The gravitational force on the Space Station obviously is not zero. It is gravity after all that makes the Space Station orbit the Earth.
The term "zero gravity" does not refer to the force due to gravity. It refers instead to all forces except gravity. When you go to an amusement park and take a ride that bills itself as having a zero g roll, or a zero g drop, gravity is not changing during the course of the ride. Your uneasy stomach tells you that something is changing. That something is your "apparent weight" or "scale weight".
You can't feel the force due to gravity. You can't conduct a local experiment that measures gravity. An example: An accelerometer placed at rest on the surface of the Earth registers an upward acceleration of 9.8 meters/second2. Why? The answer is that the accelerometer does not (and cannot) measure gravity. It measures everything but gravity. In this case, it measures the normal force from the ground that pushes the accelerometer upward. The accelerometer does not sense the downward force from gravitation, so even though the accelerometer is at rest with respect to the Earth it registers an upward acceleration with respect to the Earth.
When NASA and Dr. Tyson speak of the problems such as bone loss due to the zero g environment of space, they are referring to weightlessness (scale weight) rather than gravity.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
