Is this a problem of derived equation?
  • Thread starter Thread starter Qwer
The discussion centers on confusion regarding the equations presented in a physics class, specifically relating to kinetic energy and their derivations. The initial equation represents kinetic energy, and the subsequent equations aim to express velocity in different forms. There is uncertainty about the significance of one equation (Eq.2) and whether another (Eq.4) is correctly derived from the first. Participants clarify that the final equation relates to Coulomb's law, which is unrelated to kinetic energy, indicating a potential mix-up in the problem context. The conversation emphasizes the need for clarity in understanding how these equations connect to the problems being solved in class.
Qwer
We had this at our physics class, but since my concern only involves computation, I posted it here. I admit I was not paying attention and was just jotting down what my teacher was scribbling on the board. These are the equations in the exact order she wrote it:
k(e) = \frac{mv^2}{2} [Eq.1]
v = \frac{2 k(e)}{m} [Eq.2]
\frac{mv^2}{m} = \frac{2 k(e)}{m} [Eq.3]
v^2 = \frac{2 k(e)^2}{m^2} [Eq.4]
I.. quite.. do not follow the significance of Eq.2. And I'm not sure my teacher wrote Eq.4 correctly, because I would simply get v^2 from Eq.1 like this:
2k(e) = mv^2
v^2 = \frac{2 k(e)}{m}
So, I'm hoping someone could explain whether Eq.2 is really a derived equation.. and if it is, to be patient enough to explain how my teacher got from Eq.1 to Eq.4. I don't really know what's going on, and she's requiring us to solve the equation
F(e) = \frac{kq_1q_2}{r^2}
and I don't know what she is really looking for. Thanks in advance!
I can't really tell what you're writing here. The first expression is that of kinetic energy 1/2 mv^2. And the rest of the four equations seem to be just solving for v^2. And more importantly what do you mean by "solve the equation"? What exactly do you wan to solve it for? The final expression is just the Coulombic force exerted by 2 point charges on each other. I don't see what has that got to do with KE.
Thanks Defennder.
I was not really paying attention while copying from the board. Thanks for pointing out that it's really a kinetic energy formula. I understand now what my teacher meant by "k(e)". True, it is about solving for v^2, so could you say that Eq.4 is the correct solution? Is there also a siginificance to Eq.2?
Thanks again for pointing out what the "F(e)" formula really is. We're still starting physics, so I'm sorry if I'm sounding clueless on physics concepts. Again, my concern is pure computation. You're right, "F(e)" does not have anything to do with KE. It is another problem that she is expecting us to "solve", based on the computation process she made on the KE formula.
Thanks Defennder for bearing with my concerns. I hope you (and others) could again help with any of the questions above.
This happens to me all the time.
I don't know where Eq 2 comes from. It looks as though it should the RHS should be under a square root, if you express KE = 1/2 mv^2 in terms of v. As for the physical significance, it really depends on what problem you are solving. You may or may not be required to find v, given the other variables.
I believe the problem you posted is incomplete. So I really don't know how to help here. There are many ways in which you need to use the kinetic energy of something to find the work done by a force (something known as the work-energy theorem which you may or may not have learnt) That's about the only thing I can think of where you'll actually need to use the KE formula when solving for force. But then again there are many other possible physical possibilities such as that force formula you saw on the board may actually be required for a different part of the same question. So I really can't tell how they are related unless you post the question she was solving.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
