I Is this just a normal fluorescence of glass molecules?
The discussion revolves around the unusual fluorescence observed in a light bulb connected to a high-voltage power supply. Participants speculate that the glow may be due to energetic electrons interacting with the glass or possibly the gases inside the bulb, with some suggesting the presence of krypton gas as a potential source of the greenish light. Concerns about the possibility of x-ray production are raised, but it is concluded that the gas pressure in the bulb is likely too high for x-rays to form. The conversation also touches on the differences in gas used in light bulbs, noting that krypton can achieve higher filament temperatures than argon. Overall, the phenomenon remains a topic of curiosity and investigation.
patric44
hi guys
i recently had built a HV power supply out of an old Flyback transformer i had laying around , i think it produces about 10KV ~ 15KV not very sure but it could arc at about ( 6mm in air ) ,
and as you can see i tried to connect it to a 15W smal light bulb ( the positive terminal is connected to the strange looking rod you see on the left which is just touching the glass ) and i saw that strange effect .
( i don't know but i think its just the highly energetic electrons exiting the glass molecules which causes it to flurecence ) , give me your opinion on what is this ?! and could this apparatus produce xrays ?!
  • 14493440bd44992f6a0dd1a494b7ae4181cf9062503d8cb3309def5fdac43e54d4525fd8.jpg
the argon glow discharge is very far of this color plus i have another gas tube filled with argon and it produces a purple discharge that's a photo of it :
the other glow is more of a yellowish green glow ( it doesn't seem to be glow discharge either ) its more like of a momentary flashes not a continios glow
another thing i have to mention is that the filament is broken and its impacts rapidly with the glass of the bulb could this be the cause or anything ?!
i just want to know these electrons are exiting what ?! because it doesn't seem to be the gas inside the bulb for some reason !
unfortunately i don't have a prism or a diffraction grating .
In the second picture you posted the color seems pretty close to the one I posted, :woot:
It is hard from the pictures to see where the light is actually coming from, does it look like it comes from inside the bulb?
More physics at work, neat! Electromagnetism at work?
More small bulbs needed?
yes! it comes from inside the bulb .
what really confuses me is that the glow doesn't match any of the nobel gases glow discahrge :
so , could this be from exiting the glass molecules or any thing ?!
i read some where that the yellowish green glow in the glass is somewhat an indication of xrays ?! is that correct ?
or i couldn't be producing xrays with relativaly low voltages ( 10 ~ 15 KV )
Perhaps a mixture of gasses? Break the bulb to find out if it is the glass.
Likes Spinnor
It looks somewhat like the glow discharge of krypton in the photo below. A special incandescent light bulb (A) filled with inert krypton gas is touching a plasma globe (B). A discharge occurs through the krypton gas in the light bulb, emitting greenish light. The spectrum of the discharge as seen by a hand spectroscope (C), corresponds with a krypton spectrum found on internet (D). Even the violet lines are present.
So you might get a stronger emission from your 15 W light bulb by holding it next to a plasma globe.
Likes Spinnor and Tom.G
thank you spareine , krypton! i didn't see that one coming :) LOL
but i have a question : isn't krypton is much more expensive than argon to use it for filling a regular light bulb ?
Yes, the krypton light bulb cost about 2 euros, so it is more expensive than an ordinary bulb, but still within budget. :smile: I don't know whether krypton extends the lamp's life more than the cheaper argon, but I bought the krypton light bulb just for this experiment.
(I bought a xenon light bulb as well (same price), and its glow discharge emits a similar greenish light, but I did not succeed in seeing its line spectrum through the spectroscope.)
i searced online and , i saw that video on youtube :
i was wondering is that green glow really indicates that xrays is being produced ?!
becouse in my apparatus i think it might be the same glow , i tried to hold a neon indicator close to the bulb
the neon indicator was flashing 20cm away from the bulb ?!
and why xrays would produce such a glow ?!
Likes Spinnor
I don't think you have x-rays being produced in your light bulb. It is unlikely that the gas pressure is low enough - 10-3 to 10-4 Torr is required for soft x-rays and your bulb is likely to have a gas fill at about 80% of atmospheric pressure. You can certainly get x-rays emitted from a television tube if your anode voltage is high enough, probably 30 kV or so would do it. Have a look at this link for more info
http://www.belljar.net/xray.htm
Regarding krypton filled bulbs, I believe the switch to krypton was to allow a higher filament temperature and hence greater luminous efficacy than could be achieved with argon or a vacuum.
