Is this valid for improper integrals.
  • Thread starter Thread starter tnutty
    Integrals
The discussion centers on the validity of using two limits in improper integrals, particularly regarding the integral of functions with singularities. It highlights that while some may combine limits into a single integral, this can lead to misleading results, as seen with the integral of 1/x, which diverges. The standard approach is to separate the integral at points of discontinuity, ensuring proper handling of singularities. The conversation also emphasizes that writing the integral as a principal value can obscure its true nature, especially when evaluating limits. Properly addressing singularities is crucial for accurate results in improper integrals.
tnutty
note: INT = integral and the above and bottom arguments are the bounds for the integral. infinity
INT [ f(x) ]
-infinity
lim a - >-infinity and lim b-> infinity of :
b
INT [f(x)] = pi
a
I am just wondering if the move having two limits in one integral is valid,
as done above. Or would I have to separate it
I suppose it is, but usually we write it as:
\lim_{a \to \infty} \int_{-a}^a \arctan x dx
Oh, even better and more efficient, Thanks. To me its useless to split it into two integrals because there is not need.
Not, that is NOT how we usually write it! That is the "principal value" of the integral and can be very misleading.
For example, if we write
\int_{-\infty}^\infty \frac{1}{x} dx
as
\lim_{a\rightarrow \infty} \int_{-a}^a \frac{1}{x}dx
it becomes
\lim_{a\rightarrow \infty} ln(|a|)- ln(|-a|)= 0
The standard way to write it is, in fact,
\lim_{a\rightarrow -\infty}\lim_{b\rightarrow \infty}\int_a^b f(x) dx
which, for f(x)= 1/x, does not exist.
I'm confused myself now, while I see it going wrong for the limit to infinity this raises a question for the interval (-1,1).
<br /> \lim_{a \to 1} \int_{-a}^a \frac{1}{x}dx=\lim_{a \to 1} \ln|a|-\ln|-a|=0<br />
Now do this again with double limits.
<br /> \lim_{a \to -1} \lim_{b \to 1} \int_a^b \frac{1}{x} dx=\lim_{a \to -1} \lim_{b \to 1} (\ln|b|-\ln|a|)=\ln|1|-\ln|-1|=0<br />
But this integral should diverge should it not? So given that the function has a singularity somewhere within its integration interval should we not also split the integral up in, in this case -1,0 and 0,1?
For example:
\lim_{a \to -1} \lim_{\epsilon \uparrow 0} \int_a^\epsilon \frac{1}{x}dx+\lim_{b \to 1} \lim_{\epsilon \downarrow 0} \int_\epsilon^b \frac{1}{x} dx
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
  • · Replies 105 ·
  • · Replies 22 ·
