Calculating Perimeter and Area Sums in Infinite Isosceles Triangles
  • Thread starter Physicsissuef
  • Tags
    Triangle
Find the sum of the perimeter and calculate the sum of the areas of the triangles.]In that case, n is infinite, and the sum of the perimeter is 4P/3, and the sum of the areas is P … which is what you would expect, since each triangle is 1/4 of the previous one, so the perimeter stays the same, and the area decreases by 1/4.
Physicsissuef
908
Hi! After a tiring excursion, finally I am back... :smile:
Here is one for you:
In isosceles triangle ABC (triangle with all sides equal size) with side a, is drawn another isosceles triangle [itex]A_1,A_2,A_3[/itex] which points [itex]A_1,A_2,A_3[/itex] are in AB/2, BC/2, AC/2. Again third triangle with same attributes is drawn, fourth, fifth... infinite...
This looks like on this http://pic.mkd.net/images/404616untitled.JPG"
I think it is something like this:
[tex]P + \frac{P}{4} + \frac{P}{8} + ... + \frac{P}{2^n}[/tex] for the area of the triangle, and
[tex]L + \frac{L}{2} + \frac{L}{4} + ... + \frac{L}{2^n^-^1}[/tex]
for the perimeter.
I think also, that I can write them as:
[tex]
P + \sum_{n=2}^n \frac{P}{2^n} = P + \frac{P}{4} + \frac{P}{8} + ... + \frac{P}{2^n}
[/tex]
[tex]
L + \sum_{n=2}^n \frac{L}{{2}^{n-1}} = L + \frac{L}{2} + \frac{L}{4} + ... + \frac{L}{{2}^{n-1}}
[/tex]
[tex]n \in \mathbb{N}[/tex]
[tex]n\geq 2[/tex]
n - number of triangles
Do you know what a geometric sum is?
Yes, I write the geometric sums above in the first post. Please see them, now.
strange … I didn't find it tiring! :wink:
No. :frown:
Hint: if the lengths are halved each time, what happens to the area?
And what is ∑x^n? :smile:
(oh, and they're actually equilateral … isoceles means two sides equal)
tiny-tim I was on excursion, Skopje - Belgrade - Bratislava - Prague - Vienna (approximately 3000 km in both ways):smile:
Is this correct:
[tex]
P + \sum_{k=2}^n \frac{P}{2^k} = P + \frac{P}{4} + \frac{P}{8} + ... + \frac{P}{2^k}
[/tex] [tex]
L + \sum_{k=2}^n \frac{L}{{2}^{k-1}} = L + \frac{L}{2} + \frac{L}{4} + ... + \frac{L}{{2}^{k-1}}
[/tex]
[tex]
n \in \mathbb{N}
[/tex]
[tex]
n\geq 2
[/tex]
Hi Physicsissuef! :smile:
The L equation is correct, the P equation isn't.
Hint, repeated: if the lengths are halved each time, what happens to the area?
The area equation is incorrect, starting with the term P/8. P and P/4 are correct.
Hint: think carefully, what is the area of the 3rd triangle? (It's not P/8)
Ahh... I understand. Maybe this is better:
[tex]
\sum_{k=0}^n \frac{P}{4^k} = P + \frac{P}{4} + \frac{P}{16} + ... + \frac{P}{4^k}
[/tex]
[tex]n \geq 2[/tex]
n- number of triangles.
Also for L:
[tex]
\sum_{k=0}^n \frac{L}{2^k} = L + \frac{L}{2} + \frac{L}{4} + ... + \frac{L}{2^k}
[/tex]
[tex]\sum_{k=0}^n \frac{P}{4^k} = P + \frac{P}{4} + \frac{P}{16} + ... + \frac{P}{4^k}[/tex]
Yes (with n at the end instead of k, of course :wink:)
ok, now what is:
[tex]\sum_{k=0}^n \left(\frac{1}{x}\right)^k[/tex] ? :smile:
It will work also with "k". I sow on wikipedia.
[tex]
\sum_{k=0}^n \left(\frac{1}{x}\right)^k = 1 + \frac{1}{x} + \frac{1}{x^2} + ... + \frac{1}{x^n}
[/tex]
Why 1/x ?
No … it has to be … [tex] \sum_{k=0}^n \frac{P}{4^k} = P + \frac{P}{4} + \frac{P}{16} + ... + \frac{P}{4^n}[/tex] … doesn't it?
[tex]
[/tex]
Yes, obviously :rolleyes: … but what is that equal to? :smile:
[tex]\frac{\frac{1}{x}-\frac{1}{{x}^{n+1}}}{1-\frac{1}{x}}}[/tex]
hmm … how about [tex]\frac{1-\frac{1}{{x}^{n+1}}}{1-\frac{1}{x}}}[/tex] ? :smile:
But isn't something like this:
[tex]S=d+d^2+...+d^n[/tex]
[tex]Sd=d^2+d^3+...+d^n^+^1[/tex]
[tex]S-Sd=S(1-d)=d-d^n^+^1[/tex]
[tex]S=\frac{d-d^n^+^1}{1-d}[/tex]?
Your first term is 1, not 1/x. The formula you derived needs to be modified slightly to suit your problem.
if d=1 then also down there it will be 1..
[tex]
S=\frac{1-d^n^+^1}{1-1}
[/tex]
No, in your derivation, the first term is equivalent to r, the ratio of the n+1 term to the nth term. But in [tex]\sum_{k=0}^n \left(\frac{1}{x}\right)^k = 1 + \frac{1}{x} + \frac{1}{x^2} + ... + \frac{1}{x^n}[/tex], the first term is not equivalent to the ratio. Which is why the formula needs to be modifed in order to suit your problem.
[tex]S = 1 + \frac{1}{x} + \frac{1}{x^2} + ... + \frac{1}{x^n} [/tex]
[tex]S\frac{1}{x}=\frac{1}{x} + \frac{1}{x^2} + \frac{1}{x^3} + ...+ \frac{1}{{x}^{n+1}}[/tex]
[tex]S-S\frac{1}{x}=S(1-\frac{1}{x})=1-\frac{1}{{x}^{n+1}}[/tex]
[tex]S=\frac{1-\frac{1}{{x}^{n+1}}}{1-\frac{1}{x}}[/tex]
Sorry, you're right.
But I need to do the same for P and L, right?
[tex]S = P + \frac{P}{4} + \frac{P}{16} + ... + \frac{P}{4^n}[/tex]
[tex]SP=P^2+\frac{P^2}{4}+\frac{P^2}{16}+ ... + \frac{P^2}{4^n}[/tex]
[tex]S-SP=S(1-P)=P - \frac{P^2}{4^n}[/tex]
[tex]S=\frac{P - \frac{P^2}{4^n}}{1-P}[/tex]
is this correct?
Ohh... Again I made mistake.
It should be
[tex]S(1-\frac{1}{4})=P-\frac{P}{{4}^{n+1}}[/tex]
[tex]S=\frac{P-\frac{P}{{4}^{n+1}}}{1-\frac{1}{4}}[/tex]
Is the final answer.
Physicsissuef, that took ages!.
Look, you will lose marks, and time, in your exams if you keep using formulas without really understanding them.
Multiply (1 - x) by (1 + x + + x^2 + … + x^n) using "long multiplication" to understand why (1 - x^n+1)/(1 - x) = (1 + x + + x^2 + … + x^n). :smile:
Yes, I know that. :smile:
Just I want to ask you, why on other forum told me that the answer is [itex]/frac{4P}{3}[/itex]?
Here is one post:
4P/3 is indeed the correct answer, since;
a / (1 - r) is the sum to infinity of a G.P.
where |r| < 1, a is the first term and r is the common ratio
so;
P / (1 - 1/4) = 4P/3
Physicsissuef said:
Just I want to ask you, why on other forum told me that the answer is [itex]\frac{4P}{3}[/itex]?
Because P(1 - 0)/(1 - 1/4) = 4P/3 is the answer for n = ∞
… and looking all the way back at post #1, even though you kept doing the sums for n = N, that is what your question actually asked for:
Physicsissuef said:
[In isosceles triangle ABC (triangle with all sides equal size) with side a, is drawn another isosceles triangle [itex]A_1,A_2,A_3[/itex] which points [itex]A_1,A_2,A_3[/itex] are in AB/2, BC/2, AC/2. Again third triangle with same attributes is drawn, fourth, fifth... infinite...
But why 1-0 ? If the answer is P(1-0)/(1-1/4)=4P/3 then
[itex]\frac{1}{{4}^{n+1}}=0[/itex]
because of [tex]P(1-\frac{1}{{4}^{n+1}})/(1-1/4)[/tex].
How is possible [tex]{4}^{n+1}=0[/tex]?
If n —> ∞, then 4^{n+1} —> ∞,
and so (1/4)^{n+1} —> 0. :smile:
Strange... :smile: So what is the right answer now?
It isn't. Nor is [itex]4^{-(n+1)}= 0[/itex] for any fixed n. However, the limit [itex]4^{-(n+1)}= 1/4^{n+1}= 0[/itex] as n goes to infinity.
You tell us! :smile:
FAQ: Calculating Perimeter and Area Sums in Infinite Isosceles Triangles
What is the formula for calculating the perimeter of an infinite isosceles triangle?
The formula for calculating the perimeter of an infinite isosceles triangle is P = 2a + b, where a is the length of one of the equal sides and b is the length of the base.
How do you find the area of an infinite isosceles triangle?
The area of an infinite isosceles triangle can be calculated using the formula A = 1/2 * b * h, where b is the length of the base and h is the height of the triangle.
Can the perimeter of an infinite isosceles triangle be infinite?
Yes, the perimeter of an infinite isosceles triangle can be infinite if the length of the sides and base are infinitely long.
Is it possible to calculate the exact area of an infinite isosceles triangle?
No, it is not possible to calculate the exact area of an infinite isosceles triangle because the height of the triangle is also infinite, making the calculation infinite.
What is the relationship between the perimeter and area of an infinite isosceles triangle?
The perimeter and area of an infinite isosceles triangle are directly proportional. This means that as the perimeter increases, so does the area, and vice versa.
