Issue in the electron’s infinite self-energy
The discussion revolves around the concept of the electron's infinite self-energy as described in Richard Feynman's "Quantum Electrodynamics." Participants explore the implications of this infinite self-energy in quantum electrodynamics (QED) and propose alternative approaches to understand or resolve the issue.
  • One participant, Sergio Prats, discusses Feynman's assertion that the electron's self-energy is infinite and suggests that the use of a cut-off is not fully satisfactory.
  • Sergio proposes an alternative method to calculate self-energy using a quantum mechanical approach, suggesting that this method yields a finite result for a plane-wave state.
  • Another participant points out that the Feynman diagram presented is only the lowest-order term in the perturbation series, indicating that the full series leads to an infinite result.
  • There is a request for references to support the alternative approach proposed by Sergio, emphasizing that personal theories may not be discussed in the forum.
  • Subsequent replies reiterate that the alternative interpretation is considered personal and thus not permissible within the forum's guidelines.
Participants express disagreement regarding the interpretation of the electron's self-energy and the validity of alternative approaches. There is no consensus on the proposed methods or the implications of the infinite self-energy issue.
The discussion highlights limitations in the understanding of self-energy calculations and the challenges in addressing divergent results in quantum electrodynamics. The reliance on personal interpretations and the forum's restrictions on such discussions are also noted.
USeptim
Hello,
Reading Richard Feynman’s book “Quantum Electrodynamics” (Edited by Advanced Book Classics), I read that the electron’s self-energy is infinite and that has been a trouble for QED during 20 years. Feynman proposed a solution based on a cut-off, but that’s not fully satisfactory and I think the question remains still opened.
The Feynman Diagram that describes self-energy is:
The integral used in the space-time dominion is:
Where
· ΔE is the electron's self-energy
· V and T is the volume and the period of time and them both are infinite.
· The f's are the wave functions.
· K+ is the zeroth order propagator for a spinor using the Dirac equation.
· γμδ+(s24,3μ is the potential caused by point '3' over point '4'.
The integration is done over time and space in both points '3' and '4'. We can say that '3' emits a virtual photon and '4' absorbs it.
With this data, although we have to divide by 'V' and 'T' in order to obtain the self-energy, a divergent self-energy is obtained.
However, I think it's not correct to set the potential as γμδ+(s4,32μ since this expression is not taking into account the charge density of '3', |f(3)|2.
I think, another way to get the self-energy could be obtained by quantum mechanical means simply by:
ΔE = <f*(t4) |HSE| f(t4)>
Where HSE is the self-energy hamiltonian, that hamiltonian should be:
With this approach, the self-energy is no longer infinite, in fact for a plane-wave (dispersed over the infinite) it's zero.
Can anybody tell me where I am missed? Since for me looks clear that the self-energy should not be infinite.
Thanks a lot!
Sergio PratsNOTE: in self-interactions the initial and the final states must be the same, so this Hamiltonian must not have the same effect in the vawe-function that a normal Hamiltonian.
This is not "the" diagram for self-energy; it's only the lowest-order term in the perturbation series. The full series involves an infinite number of diagrams, and if you try to just add them all up, the answer comes out infinite. That's the problem Feynman was describing.
Do you have a reference for this? PF does not allow discussion of personal theories.
... Well, it's a personal interpretation...
Which means it's off limits here. Thread closed.
  • · Replies 25 ·
  • · Replies 20 ·
