[itex]\int\frac{n}{(n^{2}+1)^{2}}[/itex]= itself w/ Partial Fractions
Lebombo
Why when I try to evaluate this with Partial Fractions, why do I end up with the original function?
\frac{n}{(n^{2}+1)(n^{2}+1)}
\frac{Ax+B}{n^{2}+1} + \frac{Cx+D}{(n^{2}+1)^{2}}
1n = (An+B)(n^{2}+1) + Cx + D
0n^{3}+ 0n^{2} + 1n + 0n^{0} = n^{3}(A) + n^{2}(B) + n(A+C) + n^{0}(B+D)
A=0 B=0 C=1 D=0
\frac{0n+0}{n^{2}+1} + \frac{1n+0}{(n^{2}+1)^{2}}
= 0 + \frac{n}{(n^{2}+1)^{2}}
That website looks all scrambled up. Nothing seems to be aligned. Which part pertains to why this particular function ends up to simply be itself?
By the way, when I do u-sub on this function I get 1/4 and when I do partial fractions I get -1/4. Is that a sign mistake?
Also, the basis for this question was actually in regards to the series of the function in question.
I was trying to do partial fractions to create a telescoping function to evaluate the series. But partial fractions doesn't separate this function into telescoping series.
So my follow up questions is: Why does this function not separate into a telescoping form if Partial fractions can be applied to it?
Lebombo,
What you're saying doesn't make a lot of sense. As you've seen, partial fractions leads you right back to the exact same integrand, so I don't see how you were able to carry out the integration that way. Substitution is the way to go here.
The integral looks like it would be amenable to a trig substitution, but that seems like a lot of work when an ordinary substitution would do the trick.
Likes 1 person
The site works fine with Chrome on my laptop. Check your browser!
The website page goes over the method in detail, with a few examples. A review of the method may help you to find any problems with your technique.
Wolfram Alpha says: ## n^2/(n^2+1) = 1-1/(n^2+1) ##
Likes 1 person
IDK why you want to use partial fractions anyway. You've plainly got a case for a u substitution, no partial fractions or trig substitution required.
Likes 1 person
I don't see the need of a trig substitution. There is a very obvious substitution you can use as SteamKing has said.
Likes 1 person
I just [thought I] saw an opportunity to practice a partial fraction from the past chapter while working on series.
Thanks all.
