Prove IVP with Bolzano-Wierstrass & Heine-Borel
StarTiger
Tricky problem. Any tips? Thanks SOO much! :biggrin:
Let f be continuous on [a,b] and let c be a real number. If for every x in [a,b] f(x) is NOT c, then either f(x) > c for all x in [a,b] OR f(x) < c for all x in [a,b]. Prove this using a) Bolzano-Wierstrass and b) Heine-Borel property.
B-W property: A set of reals is closed and bounded if and only if every sequence of points chosen fro E has a subsequence that converges to a point in E.
H-B property: A subset of the reals has the HB property if and only if A is both closed and bounded.
(Note the function given fits HB and BW propertis by definition).
Some hints:
For WB: suppose false. Explain how there exist sequences {x_n} and {y_n} such that f(x_n) > c, f(y_n) < c and |x_n - y_n| < 1/n
For HB: Suppose false and xplain why there should exist at each point x in [a,b] an open interval I_x centered so that either f(t)>c for all t in intersection of I_x and [a,b] or else f(t)<c for all t in the intersection of I_x in [a,b]
This seems like a strange question. The Heine-Borel and Bolzano-Weierstrass theorems each state that a closed and bounded subset of \mathbb{R} is compact (each using a different characterization of compactness). However, the intermediate value theorem for closed intervals in \mathbb{R} is not a consequence of compactness, but of connectedness.
In your question, one might replace [a,b] by [0,1] \cup [2,3], a compact but disconnected set. This set possesses the Heine-Borel and Bolzano-Weierstrass properties, but the intermediate value theorem is obviously false for it (consider any function which takes one constant value on [0,1] and another on [2,3]).
While the fact you are asked to prove is true, the theorems you are asked to use to prove it seem totally inappropriate to the task.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
