What are the Confusing Aspects of Jackson Eq. 5.33 (3rd Ed.)?
  • Thread starter Thread starter shehry1
    Jackson
shehry1
I can't seem to figure out how he writes down this equation. Specifically:
a. Isn't Theta' = 90 degrees. Then why doesn't he write it out explicitly.
b. Whats the use of adding the Sin(Theta') if he is going to use a delta function using the Cos
c. What is the radius 'a' doing there. If the wire has no thickness, shouldn't the magnitude of J equal I.
d. Shouldn't J=I/Area^2 in terms of units.
Because it's more convenient to write the measure as
\delta(\cos \theta') d(\cos \theta')
rather than
\sin \theta' \delta(\theta') d\theta'
It saves a lot of time, trust me.
The current loop is in the x-y plane, where
\sin \theta' = 1
which is the same as
\cos \theta' = 0
I suppose he could have technically left out the sin(theta) and just put in 1 (just as he puts in 1/a instead of 1/r). However, perhaps he put it in so that the formula would be easier to generalize.
No. The integral of J over its cross-sectional area should equal I. That is:
I = \iint_R r \; dr \; d(\cos \theta) \; I \delta(\cos \theta) \frac{\delta(r-a)}{a}
where R is some vertical region that cuts across part of the wire. So you see, the 1/a is essential to give the correct value of I.
Yes, and it is. Or rather, J = I/Area. Remember that delta functions carry reciprocal units. So you get 1/L from the factor of 1/a, and another 1/L from the factor of \delta(r' - a).
Thanks a lot :)
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
