Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The Fukushima Daiichi nuclear plant is facing significant challenges following the earthquake, with reports indicating that reactor pressure has reached dangerous levels, potentially 2.1 times capacity. TEPCO has lost control of pressure at a second unit, raising concerns about safety and management accountability. The reactor is currently off but continues to produce decay heat, necessitating cooling to prevent a meltdown. There are conflicting reports about an explosion, with indications that it may have originated from a buildup of hydrogen around the containment vessel. The situation remains serious, and TEPCO plans to flood the containment vessel with seawater as a cooling measure.
  • #4,021
NUCENG said:
So whence cometh the damage to Unit #4 exterior? There appears to be photography showing Unit 4 intact after Unit #3 exploded. But look at Unit 3 in those pictures. There is concrete slab siding on the ground floor and two floors of open concrete support beams and girders. In the pictures showing Unit 4 damaged the seems to be another floor missing from Unit 3. The damage to Unit 4 is bent away from unit 3. Is it possible there was a second explosion at Unit 3 that caused the damage to Unit 4?
I think the following image argues against this admittedly intriguing idea:
http://livedoor.2.blogimg.jp/dqnplus/imgs/6/d/6dffb5e9.jpg
That was on 3/14, after #3 blew up but before #4 did.
The damage to building #3 seems largely complete at this point already.
#4 has no visible damage yet.
Zoom in of the above:
Compare with the next day, after whatever had happened to #4:
[URL]http://www.tepco.co.jp/en/news/110311/images/110316_1f_chijou_1.jpg[/URL]
They look about the same to me...
  • #4,022
Hello, I've been lurking here for the last month. I was happy to find a place where people actually knew what they were talking about. For that, thank you.
I found a Tepco press site with images and videos, some that I have not yet seen on any other sites.
I found the "Sampling in Spent Fuel Pool of Unit 4" video very interesting. I was surprised it is in such good shape, at least to my "not-a-scientist" eyes.
http://www.tepco.co.jp/en/news/110311/images/110414_1f_1.zip
If you have already seen these, I apologize and I will go back to my lurking.
  • #4,023
Are there any good options (i.e. free) for uploading large images to the web? I have some more Oyster Creek drawings, but they are very large. I uploaded a couple to photobucket but they have a size limit that makes the result useless.
These are both originally 5088 x 3296 pixels at 72 dpi. I've played with resizing in photoshop and saving with different jpeg quality compression ratios, but none come out clear enough to show any details.
http://i1223.photobucket.com/albums/dd509/MiceAndMen1/Oyster Creek/OysterCreekDwgRB.jpg
http://i1223.photobucket.com/albums/dd509/MiceAndMen1/Oyster Creek/OysterCreekDwgRefuelLevel.jpg
I suppose the best solution is to post the URLs to the original PDFs. I'll have to find them first, but I'll post them when I do.
  • #4,024
For those looking to pin down the location of the camera that captured the explosion of Unit 3, I used a program called Global Mapper (an excellent piece of software) to get a 3D idea of the topography surrounding the plant. Global Mapper let me download ASTER elevation data for the area. I coupled that with a topographic map I found on a Harvard website, and used Global Mapper to drape the topographic map over the top of the 3D elevation data. I drew a line from the corner of the Unit 3 reactor building through the vent stack that it was lined up with in the explosion video, and extended that line out to 16 km. Global Mapper has an additional function (one of many) that generates an elevation profile along that line.
Source data from ASTER
http://asterweb.jpl.nasa.gov/
Topo map from Harvard (Fukushima base map at the bottom of the page)
http://cegrp.cga.harvard.edu/japan/?q=category/tags/topography&page=1
The topo map was originally made in 1970, although there is a notation on the side of the map that says the air information is correct through October of 1980. There's also a disclaimer that some of the data might not be completely accurate. Nevertheless, there are multiple aerial obstructions noted at the Fukushima Daiichi site. One gives the height above ground as 82 meters, and the other as 131 meters. I'm not sure how to correlate that information with the vent stacks we've seen in all the pictures.
  • #4,025
Gah! A 3-file attachment limit to posts... OK, here is the 3D pic I generated with Global Mapper and its associated elevation profile out to about 5 km. Note the high spot is about 65 meters, and that is lower than either stack height listed on the topographic map.
  • #4,026
Here is a similar set of pics but going out to a distance of 16 km from the plant.
Has anyone tried to contact NHK or some other Japanese media outlet to ask the direct question of where the camera was situated at the time Unit 3 exploded?
  • #4,027
  • #4,028
http://min.us/"
  • #4,029
No, but I recall them saying that the cameras were located beyond the evacuation zone, which at the time of the #3 blast was 20 km in radius. So might want to try extending your search to at least 20 km from the plant.
  • #4,030
AntonL said:
http://min.us/"
Thanks AntonL!
Oyster Creek Reactor Building General Arrangement (approx. 1 MB)
http://i.min.us/ikukv6.jpg
Oyster Creek Reactor Building Refueling Level (approx. 5 MB)
http://i.min.us/ikum3E.jpg
The second pic shows a lot of little details, such as the height of the 4 reactor cavity shield plug slabs being 7 feet (2.13 meters). Note that the differences between the Oyster Creek plant and the Fukushima reactors are quite possibly non-trivial. It would be really nice if TEPCO would release a set of drawings :cool: but I don't think that's going to happen.
I'll find the URLs for the PDFs I have of the Oyster Creek drawings. There are 4 PDF files totalling about 23 MB. Hmmm... now that I think about it, there are no direct PDF download URLs, you'll have to navigate an NRC website to get to them. I'll post how to do that tomorrow.
I spent more than a few hours searching for reactor building blueprints on the NRC site, and the ones for Oyster Creek are the only ones I could find. Others haven't been scanned into PDF form yet, and still others are, I think, not publicly available at all. That's too bad because I believe the closest reactors in the US to the Fukushima Daiichi ones are the ones at Vermont Yankee and (now closed) Millstone I.
  • #4,031
MadderDoc said:
I don't think that is a plausible damage from heat.
Allow me to draw your attention to a possible suspect at the foot of the building (see attachment). It is found at the scene of the crime, in a plausible position after an assumed hammering of unit 4's north side. It appears to be a boiler tank or something of that sort, about 10 meters long, about 3 meter in diameter. It appears to have been blasted. And, perhapos significantly, it appears to be lying on top of pieces of unit 3's roof construction.
I think that's a crane.
  • #4,032
It seems that the explosions at each plant would leave distinct evidence as to its nature. A shattering (high velocity) explosion should leave some sharp ragged edges on the concrete structure. Where as propellant (low velocity) damage should show erosion.
Water turning to steam expands about 1728 times in volume. It starts out with no velocity and accelerates. The speed it obtains between its point of origin and the building walls would give it an energy impulse upon impact similar to an explosion. However, between being water and being steam at full expansion, it would behave much like a fluid. If a significant quantity of water flashed to steam and had only expanded to 2-400 times its volume at the time it initially pushed the wall panels out then it would leave the marks of a (debris laden) fluid eroding the remaining concrete structure.
Hi-res close-up pictures of the remaining vertical supports and the underside of horizontal structure should bring clarity to which event happened at which buildings. This would make the reconstruction of events more focused and productive.
liam
  • #4,033
I wonder if the reason for the higher temperature at the bottom of #3 is the cool water is being injected at the top and the heated water is leaking past the sensor out the bottom?
  • #4,034
At 252 Celsius and low pressure that water is not liquid water anymore.
Steam will not attain this temperature without external heating
  • #4,035
OnlyOneTruth said:
@TCups, you posted the picture, You remember where you got it?
I got it from a news site, and TCups annotated it.
It was the first picture released by TEPCO.
  • #4,036
Are you referring to the yellow trucks ?
  • #4,037
Dmytry said:
I don't think it'd matter noticeably that it'd take away neutrons, if the coating is very thin (e.g. a few micrometers), but a significant fraction of it would still turn into mercury, so you'd get some sort of gold-mercury amalgam. I really don't know if it would even remain there at all. Plus the mercury tends to have corrosive effect. edit: plus, perhaps, electrochemical corrosion as well, if any of gold flakes off.
That is the point. With its relatively large cross section, if you put a thin layer of gold in the area of highest neutron flux in the reactor, it won't be there very long.
  • #4,038
elektrownik said:
We will not see any isotopes until tepco will give us data about them, they give us now only I and Cs...
One of the clues would be another huge release of iodine. That hasn't happened from their data. Slow increases in iodine would potentially indicate reevolution of iodine gas due to pH in pools becoming acidic. A sudden huge release would occur from interaction with concrete releasing a whole new set of chemicals.
  • #4,039
Lacking explanation for internal hydrogen explosions in Unit 4 due to TEPCO reports of conditions in the fuel pool of Unit 4, there are two possibilities: internal explosion from another souce, or external exposion.
My experience with BWRs including refueling outages is that there is no internal source that could justify the kind of damage I see. Acetylene is used for cutting, but in small tanks brought to each work site. Most welding is arc welding. There are lubricants, but not in confined containers that could develop the kinds of forces evident in the damage.
I agree there are pictures showing the damage to Unit 4 was after the explosion of unit 3. But there seem to be significant differences between those picture of unit 3 and pictures taken after unit 4 showed damage. The early pictures show parts of the third and fourth floors still standing on Unit 3. Current pictures show only 2nd and part of 3rd floors.
My focus was the area at the wall of unit 4 which appears to be bent inwards. That is my evidence of the direction of force. I'm looking for a set of photos of unit 3 that can prove the timeline, but so far have problems with confirmed times for the photos.
  • #4,040
tsutsuji said:
Packbot(s) entered into reactor buildings 1 & 3, after opening some of the doors connecting with the turbine buildings. Measurement results are expected to be released on April 18th or later : http://www.jiji.com/jc/c?g=soc_30&k=2011041700293
http://english.kyodonews.jp/news/2011/04/86132.html
Radiation levels are at 10-49 mSv/h in Unit 1 and 28-57 mSv/h in Unit 3. Why are they not checking Unit 2?
As far as I know, the only difference between Unit 2 and the other Units is, that Unit 2s secondary containment has been flooded. Does that mean that they send these robots into the secondary containments of Units 1 and 3? And then do these radiation levels imply, that there the RPV has not been breached? (Aside from ruptured valves and such)
  • #4,041
I think what MadderDoc is pointing to (thumbnail) is one of these cranes.
  • #4,042
The way I'm picturing the cores and cooling is that there are leaks so whatever water level that can be maintained is the same level the rods will melt down to even if they have to flood the whole basement to get the water level constant. In the meantime, fluctuating water levels cause fuel to react to the environment besides the constant bleeding of contaminated water while waiting for a cool down(s).
From a previous posted link http://canteach.candu.org/library/20044507.pdf" which is in .pdf format, the author notes steam is a better coolant but when nitrogen is injected (to displace hydrogen) it causes core temperature to rise. This is the same paper that tries to cover all possible angles during a nuke accident but in hindsight omits seawater ramifications when used as coolant.
Also, how can you stop the contaminated seawater from entering and contaminating the ground water table as the ocean permeates the shoreline esp. during tidal movements?
  • #4,043
I do not agree with this statement , I do not see the missing part you are referring to, could you please point them out
AtomicWombat, crane as is crane truck or as in crane equipment from the Nuk Building ? I think I missread you you were speaking of crane truck but since so far we were talking about crane equipment..
  • #4,044
You can not trust any of the readings/reports. Because it's TEPCO and the press most of the time do not know what they are writing about.
The same website reports 270 mSv at the gateway to Unit 1. That implies that the radiation is higher inside the gateway than inside the reactor building. Make your conclusions please.
http://www3.nhk.or.jp/daily/english/18_03.html"
  • #4,045
I think that they don't check s/c yet... also there is some error in translation, from picture and tepco news I think that they send 2 robots to #3 building, and nothing yet to #1..
  • #4,046
Sorry I meant truck mounted cranes. I'm pretty sure they were there before the explosion in unit 3.
  • #4,047
Borek said:
Yes, but that height gives us only information about initial speed - we don't know mass, so we can't tell anything about amount of energy. And if I remember correctly the idea of OP was to calculate mass from this data - and this is simply impossible. It is not an accident that in the simplest approach - mgh=mv2/2 - mass cancels out :wink:
Magnificent, you are a kind of genius. I would never have got there! :eek:
I simply said that I wanted to estimate its mass if we were able to calculate the energy involved during the explosion as I know the height at which these items have gone up. If you do not want to contribute, you are not required to do so..
  • #4,048
Apparantly NISA announced that the reactor builing No 4 is now flooded in 5 meters of water. Anyone to explain this? Do they mean the SFP?
  • #4,049
liam
@liamdavis:
Thank you very much for that information. Very much looking forward to your analysis and what you can tell us about the various events at each of the buildings!
It is hard to escape the conclusion that water flashing to steam occurred at Bldg 3 and that the source of the explosion in Bldg 4 had to ultimately be the spent and un-spent fuel in the SFP.
MiceAndMen said:
Thanks AntonL!
@MiceAndMen:
Thank you also for the detailed drawings of the reactors. The last in particular gives some excellent details on the "likely" construction of the upper containment including the shield plugs (which as it turns out) are clad in carbon steel -- at least at the Oyster Creek facility.
As above, flashing of water to steam seems at least to me to be what occurred in part at Unit 3. It also seems likely that the initiating event was an explosion occurring in the primary containment. How to get from "A" to "B" is a question that I don't think has been answered fully.
As for Unit 4, the shattered upper mast of the FHM seems to indicate a violent event in the SFP with lots of energy transferred to the mast, but perhaps not so much damage to the remainder of the FHM. And additional plans detailing what might have been directly behind the blown out panels at the north and south face of Bldg 4 would be most interesting.
@all:
Coming at the explosion in the lower building, here's a hypothetical question for someone who knows reactors:
In the myriad of pipes, tanks and accessories hooked up to the RPV and primary containment and housed outside of the RPV and primary containment, in the lower building (other than the torus suppression pool), are there any of them that might explode as a direct result from over-pressure, steam or hydrogen accumulation inside the primary containment or RPV?
  • #4,050
drdodge said:
if anyones interested
latest drone photos here
http://www.cryptome.org/
dr dodge
Nice one!
not read the last 20 pages but there's a good situation update here:-
http://cryptome.org/0003/daiichi-assess.pdf
I know there are translation problems, but I just love the way they say "unit one is relatively stable"!
Relatively! ... to what!
49K
  • · Replies 41 ·
  • · Replies 2K ·
60
451K
20K
  • · Replies 763 ·
274K
  • · Replies 38 ·
16K
11K
