Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #10,021
Also, if filters reach capacity every 5 hours (assuming that is the worst case scenario), they will be going through roughly 3600 cartridges per month. I wonder if our friends at Kurion have planned for the possible eventuality of supplying many thousands of cartridges over the next year or two? And as clancy pointed out-
That would be about 200 Sv/h at 10 meters for all basement water C137 collected in a bucket. Nice. Or rather... "ouch".
That figure underscores how daunting of a task this recycling idea really is, making it difficult for me to feel optimistic about its long term sustainability.
At this juncture, the ball seems squarely in Kurion's court. Areva hangs around trying to be useful somehow, and Tepco is forced to find other means to store or dispose of the water.
  • #10,022
None of the process problems would matter if there were adequate storage for the contaminated water.
Yet 100,000 tons is the capacity of a small tanker. Presumably TEPCO could afford to buy a couple of double hulled tankers for use as a temporary storage depot. The tankers might need to be scrapped after use, but they are cheap, maybe $50mm tops.
In fact, if the water could be transported elsewhere, it would allow a much better shot at setting up and running a decent purification facility, something impossible in this small site where everything has to be shoehorned to fit.
Is there some fatal objection to such an approach?
  • #10,023
Using an unmanned tanker anchored within the harbour basin of the plant, it seems like a no brainer to me: There is nothing to lose compared to letting the water drain directly into the ocean.
As for using the tanker to ship out the water however, I suspect the tanker idea becomes more viable only *after* the water has been processed. It was my impression that this was the idea with the floating platform too: Decontaminate the water as much as possible, pump it into the "megafloat" and tow it to Rokkasho-mura for final cleanup.
The radiation on a vessel filled with that much cesium solution should be a serious hazard to any crew and I can't see much political acceptance from any prefecture near the plant to let this pass their coast, let alone dock in a port.
  • #10,024
Here are some objections that I can think of:
1) You are giving the radiation more "legs"; disabled radioactive tanker drifting off of Tokyo would be a Tom Clancy novel, nothing you want in real life.
2) Tankers are not designed to be leakproof, so you could easily have a spill during the filling process -- and that would mean you now have an unapproachable tanker full of radioactive crud. This could be mitigated if we started a couple of months ago, perhaps somebody has and we don't know about it.
3) If another tsunami hits while the tanker is being filled?
4) Fukushima harbor is apparently shallow (they call it the "shallow draft quay") so getting the stuff out to the tanker may be as complicated as the decontamination process, and just as risky. You are going to have long tubes with radioactive water going out to a ship bobbing at anchor, and you cannot allow any of it to spill.
5) I do not know if the bridge of a tanker will be sufficiently isolated from the hold for the crew to be able to operate it if the hold is highly radioactive. The last thing you want is a Mary Celeste situation.
I think railway cars might be a solution, or tanker trucks. (They have a pretty cool radio-controlled excavator, why not a truck cab?) One thing to avoid is all of the radioactive eggs in one basket, as tempting as it sounds. We know how to deal with things like leaking tank cars, leaking tankers are a different matter. (Break out the poly wrap!)
  • #10,025
MadderDoc said:
It is not plausible that the exhauster after having done relatively little to lower the air contamination over a 5 day operation period, then suddenly over a 12 hour period appears to have decimated it. It is also not plausible that it is due to a measurement or graphing error.
But Tepco could plausibly have opened the door, letting in fresh air. Yesterdays press article reported that taking this step had been authorized.
I wrote this with reference to measurements published in
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110617_01-e.pdf
I shall have to eat my words, seeing this document:
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110619e2.pdf
According to this latter document, the radioactive content in unit 2 air on June 18th was back up where it was before and during the first 5 days of exhauster operation -- iow it appears to have had no real effect -- and there is reason to think that the drastic drop displayed by the former document was a fluke and may well not have reflected reality in unit 2. Nonetheless Tepco says it will commence gradually opening the doors to unit 2 starting today (March 19th) -- only now not with reference to any strong effect of the exhauster, but rather with reference to the expectation that opening doors will not significantly change the radioactive content in air at the boundary of the plant.
  • #10,026
etudiant said:
Thank you for the extra insight on the filter changes.
The question remains for me, how do they plan to capture 300PBqs of cesium in cartridges that need to be manually changed. The cesium is about a million curies worth, unless I've dropped a decimal somewhere.
According to http://www.meti.go.jp/press/2011/06/20110609006/20110609006-2.pdf the purifying facility is supposed to produce, over one year :
tsutsuji said:
2,000 m³ of radioactive sludge will be produced. 400 caesium absorption towers will be spent.
I have no idea how the petabecquerels are distributed between the towers/cartridges and the sludge, but the fact that cooling is mentioned only in connection with the sludge made me imagine that the sludge was hotter than the cartridges.
clancy688 said:
You did. It's ten million. ;)
I'd be interested in how many becquerels one filter is supposed to capture until it's changed. Or does anybody know how to convert "4 mS/v" of C134 and C137 at a 1:1 ratio into becquerel?
My understanding is that the 4 mSv/h
* were measured in the air outside the vessel
* dropped to 1 mSv/h or lower after flushing
So you cannot consider these 4 mSv/h as something measuring directly the radiations inside the cartridge/tower.
  • #10,027
MJRacer said:
They may have just discovered a novel way to remove large amounts of radioactive contamination from water in just three steps: (1) pour bucket of diesel fuel into contaminated water, (2) form air/oil/water emulsion, (3) filter through Kurion oil+technetium cartridge and Bob's your uncle! By trapping the oil droplets in the Kurion cartridge, the hot particles are also trapped. If this is happening, then one should be able to take a sample of what was collected in the first oil+technetium cartridge and see if large quantities of cesium and perhaps iodine are being trapped. They shouldn't be, as the next two cartridges are where the cesium and iodine, respectivelly, are supposed to be trapped.
If my theory is shown to be valid, then no flocculation step is necessary. The system will have shown itself to be effective at trapping hot particles in only 3 steps. However, the operational difficulties of dealing with hot cartridges may be very challenging.
The system is an unexpected over-performer.
Perhaps something good will come out of it sooner than expected.
  • #10,028
No, though we hope the above statement doesn't turn out to be a real life eventuality with any of the tepco staff.
The long term viability of storing water is also in question, and though i am not professionally in a position to field any recommendations, it sometimes helps to hear observations presented out loud.
  • #10,029
Well, in that case you'd not only have highly radioactive waste, but highly flammable radioactive waste.
  • #10,030
As I understand it , when diesel , it is not as flammable as gasoline :
http://en.wikipedia.org/wiki/Flammability
http://en.wikipedia.org/wiki/Flash_point
diesel fuel rated 2 as material that must be moderately heated or exposed to relatively high ambient temperatures before they will ignite
  • #10,031
This can be probably further moderated by additives. Whether it makes sense (that is, doesn't pose additional problems with increased amount of waste) is another question.
However, if the idea is viable, it should work with other oily substances as well, some of them are much less flammable.
  • #10,032
From NISA's 174th press release http://www.meti.go.jp/press/2011/06/20110619001/20110619001.html (Japanese), there is this figure http://www.meti.go.jp/press/2011/06/20110619001/20110619001-8.pdf provided with the announcement that the water level in the reactor of unit 4 is going to be raised by injecting water from below.
See also the diagram in http://www.47news.jp/CN/201106/CN2011061901000328.html explaining that the water level being too low, the radiations from the shroud and dryers are no longer shielded.
  • #10,033
Thank you, tsutsuji, for this incremental information.
It does leave me confused.
The Kurion modules were stated to be cesium specific and able to pick up all but 0.1-0.01% of it. Given the close to 50 kg cesium in the water, as joewein calculated in post 10035, there will be a kilogram of cesium per train per month, using all 4 trains and assuming a 1 year operations. That suggests very hot cartridges, excellent from the perspective of the cleanup if the vitrification works, but very hard to reconcile with a 4 mSv/h radiation measure in the vicinity of the cartridge.
  • #10,034
An Asahi article provides the figures for the radiation measurement after flushing :
Slightly past 3 a.m. on June 18, TEPCO began the purifying operation by pumping in low-level radioactive water, which lowered the radiation levels to 1.76 and 0.95 millisieverts per hour, respectively.
http://www.asahi.com/english/TKY201106180163.html
I previously wrote that the flushing was made with "clean water". That was a bit wrong. Actually it seems that the flushing is performed using the above mentioned "low-level radioactive water".
If you look at http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110617_04-e.pdf only the red modules (chabazite ?) are cesium specific. The green modules (where the high radiation problem is occurring) are technetium specific and the yellow modules are iodine specific.
In the June 19th press conference ( http://www.ustream.tv/recorded/15480184 ), if my understanding is correct, the NISA people say that the 4 cesium specific red modules are rotated from time to time so that the first module, which bears the biggest burden is not always the same one. Using this rotation system, the facility was supposed to be able to run over an extended time without any cartridge change.
  • #10,035
In the drawing there is an arrow going from the RPV area into the SFP area.
Does this mean that they now have confirmed that there is a (small) leak from the RPV area into the SFP area?
I think this was something rmattila suggested a long time ago also as a possibility for the units #1 - #3. The idea was that this route would perhaps better guarantee that the core area would be cooled.
Now this confirms that it is at least technically possible.
  • #10,036
Thanks for the added input.
This makes the design much clearer. It appears to reflect a sensible set of choices, which would also allow the entire set of skids to be changed out monthly. Consequently, there would be no need either for workers to manhandle each cartridge individually, which had been my perception before. So the cartridges might be fairly hot, but still within acceptable range.
Still, current reality is that the system has not yet really been run and time is short. Any further comments on possible fallbacks?
  • #10,037
The drawing's caption ピットの水がプールに流入 means "the water in the pit flows into the pool".
The article text says プールにつながるピットの水位も低下した : "the pit being connected with the pool, the water level in the pit dropped too".
Further explanations are provided in http://www.asahi.com/national/jiji/JJT201106190076.html : between March 15th and March 20th the water level in the spent fuel pool was so low that the difference of pressure between the pit and the pool allowed water to leak from the pit to the pool. After March 20th the water rose in the pool and the gate between the two became watertight again.
  • #10,038
Has anybody seen a report on how long it takes to replace the filter skid, and how many filter skids they have? It is a modular unit that is designed to be replaced.
I hope the issue isn't that since Kurion is a start up, they don't have the resources to manufacture filter units very quickly. That would have been a bad choice of supplier.
From the media reports, it doesn't seem like this first filter unit is anything very special. It seems to be a carbon filter with zeolite instead of carbon. (Oh, excuse me, "surfacant treated zeolite (STZ)" which means that they sprayed soap on it.)
There is surely a plant in China that can stamp out a few of these per day. Given the urgency to the world, a phone call from the Japanese government to one of the big manufacturers would get an expidited response.
If that is the issue start looking for a bunch of DHL trucks to appear on the webcam soon.
  • #10,039
Thanks very much for the translation.
Is Unit 5 mentioned anywhere? Because the latest TEPCO status update seems to suggest this work has now ben done at 4 & 5:
- From 9:14 am to 11:57 am on June 19, we injected fresh water to the
reactor wells and pools for setting temporary equipment of Unit 4 and
Unit 5, in order to improve the working environment (to reduce radiation
dose) in the 5th floor of the reactor building of Unit 4 and Unit 5.
From http://www.tepco.co.jp/en/press/corp-com/release/11061907-e.html
  • #10,040
This must be mistake, according to tepco unit 5 is perfect fine, reactor is loaded with fuel and closed
  • #10,041
tsutsuji said:
<..>After March 20th the water rose in the pool and the gate between the two became watertight again.
Ouch. There goes the only decent explanation we had of the hot water in the reactor cavity.
  • #10,042
I looked at the Japanese version of this TEPCO info and I think it only mentions 5th floor, not reactor 5. Perhaps someone could confirm, in which case it is indeed an error with the English version.
http://www.tepco.co.jp/nu/f1-np/press_f1/2011/htmldata/bi1574-j.pdf
  • #10,043
Does this relate to the need to keep the contents of the equipment pool (e.g. the steam dryer and the steam separators) covered? Going in through the bottom of the reactor would be taking the long way around, and implies that debris on the refueling floor will prevent access to the top of the equipment pool for quite a while yet.
  • #10,044
MiceAndMen said:
<..> Going in through the bottom of the reactor would be taking the long way around, and implies that debris on the refueling floor will prevent access to the top of the equipment pool for quite a while yet.
The chosen route for feeding the water also puzzled me, but I can't see how it implies that access to the equipment pool is prevented by debris and will be so prevented for quite a while yet. There could be many other reasons why this route has been chosen.
  • #10,045
Your reading is correct, it mentions only the 5th floor of unit 4, but not unit 5:
6月 19 日午前9時 14 分から午前 11 時 57 分まで、4号機原子炉建屋5階の環境改善(線
量低減)のため、同号機原子炉ウェルおよび機器仮置きプールに淡水の注水を行いまし
た。
This confirms the leak between the reactor pit and the pool between March 15 and 20, which is assumed to have saved the fuel in the pool from worse damage.
I am wondering how much of the temperature of the water in the reactor pit can be explained by heat conduction through the gate separating them. The reactor well itself sits insulated inside the containment, so not that much heat should flow via its walls.
  • #10,046
MJRacer
Re your separation by oil ---
you obviously have experience ... thank you for contributing.
i pray you are on to something. Those guys deserve a break.
If oil has affinity for these contaminants, (and why not? oil has great surface tension)
perhaps the answer was embarassingly simple - dairy equipment , modern version of the old hand-cranked cream separator , might do the pretreatment job. Sure would be nice to have 90% of the contamination bottled up in a few drums of oil . They could be wrapped in lead sheet and handled with forklifts.
Your elegant solution would be right in line with Mother Nature's sense of humor.
i'm watching for that one.
thanks -
old jim
  • #10,047
Tepco plans to destroy the treatment system:
The leak was found at 9PM on June 18 by the worker conducting the inspection. The safety valve [rupture disk] of the oil/technetium unit was broken, and there was water between the cylinder [vessel] that contains zeolite and the container that holds the cylinder. The safety valve is designed to break when the pressure inside the vessel gets high. TEPCO believes it may be the result of having to repeatedly start and stop the pump. The purpose of the safety valve is to prevent the hydrogen leak during the system halt. TEPCO is considering closing the valve leading to the safety valve during the operation.
http://ex-skf.blogspot.com/
Can I shout "NO" loud enough for them to hear me in Japan? You do not do this. If a fuse blows, you do not replace it with a straght wire unless you want to burn up your house. It is the same with water pressure.
The problem that they are facing is called "water hammer." It is a well known phenomon. All they need to do is put an inverted cylinder into the system to absorb the shock from start up/shut down. There are better solutions but this is what they have time for. It is possible that there are water hammer arresters in the system and they are simply flooded and need to be drained. If there is nothing to deal with water hammer in the system, then Kurion is a bunch of snake oil salesmen.
  • #10,048
It's good to see the IAEA is as committed to transparency as ever. The 151 IAEA member states will meet this week in Vienna for 5 days.
IAEA Director General Yukiya Amano called the ministerial meeting to learn lessons from the March 11 Fukushima accident and plot strategies to improve nuclear safety.
http://www.bloomberg.com/news/2011-06-20/fukushima-disaster-failures-kept-behind-closed-doors-at-un-atomic-meeting.html
  • #10,049
http://www3.nhk.or.jp/daily/english/20_13.html
Tokyo Electric Power Company, or TEPCO, halted the filtering system only 5 hours after it went into full operation on Friday. Readings around one of the system's devices indicated higher-than-expected radiation levels.
TEPCO engineers suspect that the density of radioactive substances in the contaminated water was greater than had been predicted.
They initially thought that the device had absorbed large volumes of oil and sludge containing radioactive material. But in a test conducted on Sunday, high radiation levels were registered for equipment set to the lowest of 3 absorption levels.
In another test on Monday, TEPCO adjusted the flow of the contaminated water through the equipment.
This is bad if the initial monthly change has to be revised to 5 hours due to an elevated density ...
2 orders of magnitude shift in projected contamination ?
What would this do for the schedule ?
I suspect they do not know yet why , and this would be the simplest explanation , allthough it then means they were wrong on the total level of contamination from the start
  • #10,050
The sensible thing to do would be to progress from the lightly radioactive water used last week for testing to the next more radioactive water in storage.
At the end of the day, one cubic meter freed up is a cubic meter, doesn't matter how contaminated it was if it can now be reused for cooling instead of 500 t of additional water per day from the dam.
You don't want to have the most radioactive water from the unit 2 basement in the system while you still iron out the kinks. I assume that's what they would be doing too. Even more surprising then when they should declare that things are going wrong because the water was too radioactive!
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
465K
20K
  • · Replies 763 ·
281K
  • · Replies 38 ·
16K
12K
