Comp Sci JAVA CODING - Implementing methods for a game, API
  • Thread starter Thread starter geforce
    Coding Game Java
The discussion revolves around implementing the `createPlayfield()` method in a Java game using the ACM graphics library. The method aims to create a grid of colored `GRect` blocks based on specified dimensions and positions. Key issues include confusion about how to properly initialize and populate the list of blocks, as well as aligning the blocks correctly according to the specified row and column calculations. Participants express a need for clarity on where to insert code for block placement and how to utilize existing methods effectively. Overall, the thread highlights challenges in understanding method implementation and object-oriented design within the context of game development.
geforce
Code:
import acm.graphics.*;
import acm.program.*;
import java.awt.Color;
import java.util.Iterator;
import java.util.Random;
import java.util.List;
public class LAB1
	final static int BLOCKWIDTH = 50;
	final static int BLOCKHEIGHT = 10;
	final static int NBLOCKS = 10;
	final static int BLOCKROWS = 5;
	final static int ROWZERO = 50;
	final static int ROWSEPARATION = (5*BLOCKHEIGHT);
	final static int WIDTH = (BLOCKWIDTH*NBLOCKS);
	final static int HEIGHT = 600;
	public static java.util.List<acm.graphics.GRect> createPlayfield()
		Random r = new Random();
		List<GRect> l = null;
		int x = 0;
		int y = ROWZERO - BLOCKHEIGHT;
		Color c = new Color(r.nextInt(256));
		addBrick(l,x,y,BLOCKWIDTH,BLOCKHEIGHT,c);
		for (int i = 0; i < BLOCKROWS; i++)
			i = (i * ROWSEPARATION) + ROWZERO;
			for(int j = 0; j < NBLOCKS; j++)
				j = j * BLOCKWIDTH;
	public static void addBrick(java.util.List<acm.graphics.GRect> l, int x, int y, int width, int height, java.awt.Color c)
		l.add(createBrick(x,y,WIDTH,HEIGHT,c));
	public static acm.graphics.GRect createBrick(int x, int y, int width, int height, java.awt.Color c)
		GRect s = new GRect(x,y,WIDTH,HEIGHT);
		return s;
	public static acm.graphics.GRect intersect(acm.graphics.GObject o,java.util.List<acm.graphics.GRect> l)
		GRectangle r = o.getBounds();
		for(GRect e : l)
			if(e.getBounds().intersects(r))
				return e;
		return null;
Problem I have is the createPlayfield() method, I have no idea on what to do, this is the description..
createPlayfield is a static method that returns a List of GRects. Each GRect is coloured randmoly and is
of size BLOCKWIDTH x BLOCKHEIGHT. The blocks are placed in a grid BLOCKROWS height x
NBLOCKS. The i'th row of blocks has its upper edge aligned with row i * ROWSEPARATION +
ROWZERO. The j'th column of blocks has its left edge aligned with j * BLOCKWIDTH. You may
find it useful to implement this method using the addBrick method below.
API's : The acm.graphics.GRect Class.
As you can see I tryed to do it but haven't done well, it's a very confusing description.
so... no one?
What does "haven't done well" mean? Are you getting output? Compile-time errors? Run-time errors? Help us out here.
Code:
     int x = 0;
     Color c = new Color(r.nextInt(256),r.nextInt(256),r.nextInt(256));
      // Where to implement how to insert the blocks into a grid?
     for (i = 0; i <= BLOCKROWS; i++) //
     {// How to implement that i'th row is aligned with i * ROWSEPARATION + ROWZERO
        i = i * ROWSEPARATION + ROWZERO;
          for (j = 0; j <= NBLOCKS; j++)
          {// How to implement that i'th row is aligned with j x BLOCKWIDTH;
             j = j * BLOCKWIDTH;
             addBrick(l,x,y,BLOCKWIDTH,BLOCKHEIGHT,c); // How to implement i and j into the list of grects.
        return l;
These are my problems and there's some more, I think my other methods are wrong too.
I know what to do but I don't know where to implement the code, I don't know how to that's why I need help, If I knew the design I would of done it myself, I just don't know "Where to put the code" and "Where it belongs".
The things I put in the comments are my main issues in this method and also that I'm not sure if I'm intializing variables that I don't need to before the constructor of addBrick, or if I'm adding it too late or without a proper loop etc.
