The discussion centers on a code snippet intended to print the squares of numbers between 100 and 150, which repeatedly crashes. The original code fails due to incorrect loop syntax, specifically the lack of an increment for the loop variable "i" and the absence of proper squaring logic. Instead of incrementing "i", the code attempts to use "i*i" without assigning it to anything, leading to an infinite loop. To correct the code, it is essential to increment "i" within the loop, allowing it to eventually reach the upper limit of 151. The revised code should look like this: for (var i=100; i<151; i=i+1) { var square = i*i; console.log(square);}Alternatively, using the increment operator "i++" is recommended for simplicity. This adjustment ensures the loop terminates correctly and prints the desired squares.
