Joints/fixtures for a beam bridge
  • Thread starter Thread starter chebyshevF
    Beam Bridge
For a small-scale cable-stayed bridge project, effective joints and fixtures are crucial for stability. Glue is being considered, but its reliability is uncertain, leading to exploration of alternatives like angle brackets. The challenge also includes securely attaching a 0.7mm diameter wire to the deck and pylon, with glue ruled out. A small rubber ball fixture was found unsuitable due to its size, prompting suggestions for other materials. Tie wraps were mentioned as a potential solution for securing the wire.
chebyshevF
I have a group project where we must build a small scale, cable-stayed bridge, with only one pylon (it's really an observation deck). The actual bridge is going to be a beam one.
I'm just wondering if anyone knows of some decent joints/fixtures that can be used to hold the wood pieces together? We're looking into glue but not so sure whether this might hold up? What about angle brackets?
Also we're kinda stuck as to how we should attach the wire (0.7mm in diameter) to the actual deck and pylon. We're definitely not going to use glue. We've looked into this small black rubbery ball shaped thing, but the opening is a bit too big for our wire and we can't find anything smaller. Anyone have any ideas for what material or fixture we could use?
Thanks.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
