Hetware
- 125
- 1
I having a bit of trouble understanding Joos's treatment of virtual displacements. I am referring to pages 114 and 115 of Theoretical Physics, By Georg Joos, Ira M. Freeman
http://books.google.com/books?id=vI...ce=gbs_ge_summary_r&cad=0#v=onepage&q&f=false
If I consider, for example, an iron mass suspended by a rigid non-magnetic rod, length a of negligible mass, and universally pivoted at the origin of my coordinate system, I can write the equation of constraint as:
f(x,y,z)=x^2+y^2+z^2-a^2=0
Now \partial _xf=2x=0, \partial _yf=2y=0, \partial _zf=2z=0. So forming the expression corresponding to equation VI-18 leads to the astounding conclusion that:
\partial _xf\delta x+\partial _yf\delta y+\partial _zf\delta z=2(x\delta x+y\delta y+z\delta z)=0(\delta x+\delta y+\delta z)=0
According to VI-19, I form:
(\vec{F}+\lambda \vec{\nabla f})\cdot \vec{\delta r}=0
Which stands to reason since, by the assumption of static equilibrium \vec{F}\cdot \vec{\delta r}, and we also have \lambda \vec{\nabla f}\cdot \vec{\delta r}=\vec{0}\cdot \vec{\delta r}=0.
The text following equation VI-19 states that I can choose λ such that F_{z}+\lambda \partial _zf=0.
Either I'm missing something stated in the text, or there are unstated assumptions being made.
From my limited understanding of Lagrange multipliers, I might form g(x,y,z)=x^2+y^2+z^2 and insist that \vec{F}+\lambda \vec{\nabla g} =0. I could then choose \lambda such that F_{z}+\lambda \partial _zg=0, so long as \partial _zg≠0.
Am I correct in understanding that the \partial _xf,\partial _yf,\partial _zf are to be interpreted as behaving as my function g(x,y,z)=x^2+y^2+z^2 would have them behave?
If my understanding is correct, then what proof do I have that "In this sum of 3N terms we can select the multipliers in such a way that the last l terms vanish."?
