Jumping perpendicular out of a fast spaceship will retain your speed right?
Jumping straight up from a horizontally moving spaceship will not alter your horizontal speed; you will continue moving at the same velocity as the spaceship. Unlike jumping from an airplane, where air resistance plays a role, in space, there are no opposing forces acting on you immediately after the jump. To return to the spaceship, you would need to use a thrust mechanism or a tethered line. The principles of motion in space demonstrate that you maintain your momentum until acted upon by another force. Understanding these dynamics is crucial for grasping concepts like F=ma in a vacuum environment.
lamp23
If u stand on top of a spaceship, u will not be thrust backward?
U only do on top of an airplane because of air resistance?
So if u jump up out of a horizontally moving spaceship, after you jump out you are moving with the same horizontal speed as you were inside the spaceship? U just have to thrust downwards to get back?
Or use a tethered line to get back. There were four untethered space shuttle space walks where a thruster pack was used to allow the astronaut to move around.
http://en.wikipedia.org/wiki/Extra-vehicular_activity
Yes, that is exactly correct. Thinking about space dynamics is the best way to understand F=ma. You will continue to have the same velocity until acted on by some outside force (jetpack, tethered line). Its a bit hard to fully grasp here on earth, because we are constantly acted upon by various forces. (Gravity, pressure, wind resistance, etc.)
lamp23 said:
1) If u stand on top of a spaceship, u will not be thrust backward?
2) U only do on top of an airplane because of air resistance?
3) So if u jump up out of a horizontally moving spaceship, after you jump out you are moving with the same horizontal speed as you were inside the spaceship?
4) U just have to thrust downwards to get back?
1 - Top?
2 - Air resistance [STRIKE]and gravity[/STRIKE]
3 - Yes
4 - Down?
Mother nature did not endow ur spaceship witth the gift of absolute rest, so yes, relative to the ships frame you will go 0 mph after jumping out of it.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
