Just got accepted a job as a reader/grader
  • Thread starter Thread starter johnqwertyful
    Job
Grading assignments in a math department requires a systematic approach to ensure fairness and consistency. It is recommended to grade by marking each problem across all papers before totaling scores, which helps mitigate biases that may arise from a student's performance on earlier questions. To further reduce bias, graders should avoid looking at students' names during grading; ideally, names should be on a separate cover page. If graders need to create their own solutions, seeking assistance from professors or fellow graders is encouraged to maintain accuracy. Additionally, strict adherence to the professor's policies on late submissions and academic integrity is crucial, as graders are responsible for enforcing these rules rather than making exceptions.
johnqwertyful
For the math department. I'm super excited. I'm an undergraduate junior math/EE major. Anyone ever be a grader? Any tips? I'm only grading bio calc c 3 hours a week, but it's still cool. Pays well too. :)
- Don't grade by going through each paper in its entirety before moving onto the next. Instead, go through all the papers marking only the first problem on each. Then give them a shuffle, go back to the top of the stack, and go through question 2 on all of them (and so on). Only add up the points at the very end. This does two things: it helps ensure you grade each question in a consistent manner for everyone, and it prevents a student's performance on the previous questions from unconsciously biasing how generous you are on later questions. If you will be working with other graders to mark the same set of assignments, this is generally how you have to do it anyways to ensure fairness.
- Try to avoid looking at the student's name when marking the paper. You can have the most egalitarian views in the world on gender, race, and culture, but biases still have a way of creeping into how much we are willing to give different people the benefit of the doubt—even if you're not aware of it. Ideally, names on assignments should be written separately on a cover page that can be folded back on every paper before starting to grade. If this is not the policy of the class you are marking, just do the best with what you have.
- If you are required to produce your own solutions to the assignments you grade, don't be embarrassed to ask for help from the professor or other graders if you find yourself stuck. It's obviously essential that your solution set be accurate, and everyone needs help now and then even on things they know well.
Edit:
- Abide strictly by any policy the professor may have set for handing in things late, etc. (such as marks being taken off or the assignment not being graded at all). It should go without saying that the same goes for the university policies on more serious matters like plagiarism. It is the professor's (and/or the faculty's) prerogative to decide how flexible he or she wishes to be, and if a student has a legitimate reason for being late, etc., the prof is the one they need to take it up with. Don't put yourself in a precarious position by bending the rules for someone. It is your job to dispense grades, not mercy.
Basically everything I was planning, but always a good thing to hear it from someone else. Thanks for the reply! :)
I added another (very important) comment shortly after you replied, just FYI.
Awesome. Thanks man. I agree with that one for sure, I appreciate the advice.
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
