Kepler, Newton, Gravity, error
The discussion revolves around the application of gravitational equations and Kepler's laws, specifically examining the relationship between gravitational force, centripetal force, and orbital mechanics. Participants explore the implications of these equations and seek to identify errors in their interpretations and calculations.
  • One participant equates the gravitational force and centripetal force to derive a formula for G, leading to a contradiction when substituting into Kepler's law.
  • Another participant corrects the first by stating that the correct form of Kepler's law does not include the sum of masses (M+m) on the left side, suggesting there is no contradiction.
  • A third participant expresses confusion over the referenced equations, noting that they appear to be equivalent despite differing presentations.
  • Further clarification is provided regarding the center of mass and its role in the gravitational and centripetal force equations, emphasizing that the distances used in these equations are not the same.
  • One participant acknowledges difficulty in deriving the correct period from the equations and questions the presence of Gm versus G in the denominator.
  • A later reply identifies a typo in the previous equations and restates the correct form, reinforcing the importance of the center of mass in the calculations.
  • Another participant admits to misreading the context and acknowledges the correct interpretation of the equations, expressing embarrassment over the oversight.
Participants exhibit disagreement regarding the correct application of Kepler's law and the interpretation of the gravitational and centripetal force equations. While some corrections are made, no consensus is reached on the initial claims, and confusion persists about the relationships between the variables involved.
There are unresolved issues regarding the assumptions made about the distances in the gravitational and centripetal force equations, as well as the implications of the center of mass in orbital mechanics. The discussion reflects varying interpretations of the equations and their applications.
NCStarGazer
Looking at the gravitational equation
F=G*(M*m)/r^2
F = ((V^2)/r)*m
If you set the two equal and solve for G you get:
G = ((V^2)*r)/M
Substituting (4*pi^2*r^2)/T^2 for V^2 you now have
G = (4*pi^2*r^3)/(M*T^2)
With solution for G, look at Kepler's law with Newton's update,
(M+m)*P^2 = (4*pi^2*a^3)/G
Substituting the G solved for into Kepler's equation and consider working with a perfect circle, r will equal a and T will equal P.
Now, once you substitute in the solved G, simplify...
You Get
(M+m)*P^2 = P^2*m
This is obviously not true!
Please let me know where the error is in my observation.
Thanks!
No! The law is [itex]MP^2 = 4\pi^2a^3/G[/itex] (see here). In which case there is no contradiction (hardly surprising given the above form of Kepler's Law is derived from Newton's law of gravity).
Well... I am confused, as the link you reference has 4π2a3 = P2G(M + m) under "Conversions for Unknowns", which is the same as what I referenced (M+m)*P^2 = (4*pi^2*a^3)/G.
A bit out of order. jmb's response first.
Sorry, jmb, but NCStarGazer has the right expression.
[tex]\tau^2 = \frac{4\pi^2}{G(M+m)} \,a^3[/tex]
The source of NCStarGazer's error:
F=G*(M*m)/r^2
F = ((V^2)/r)*m
You are assuming that the r in Newton's law of gravity and the r in the centripetal force equation are one and the same. They aren't. Both objects are orbiting their center of mass. Given that the distance between a pair of objects of mass m and M is r, the distance from the object with mass m to the center of mass is
[tex]r_{cm} = \frac M{M+m}\,r[/tex]
The centripetal force needed to sustain a circular orbit about the center of mass is thus
[tex]F=\omega^2 r_{cm} = \left(\frac{2\pi}{\tau}\right)^2\,\frac{M}{M+m}\,r[/tex]
Combining this with the gravitational force yields
[tex]\frac {GMm}{r^2} = \left(\frac{2\pi}{\tau}\right)^2\,\frac{M}{M+m}\,r[/tex]
Solving for the period,
[tex]\tau^2 = \frac{4\pi^2}{G(M+m)}\,r^3[/tex]
D H
Thanks, I see how the center of mass can bring clarity. In working with your post I am still having trouble getting
[tex]\frac{GMm}{r^2}= \left(\frac{2\pi}{\tau}\right)^2\frac{M}{M+m}\,r[/tex]
To yield your answer, I placed it in Maple and it always returns a version that has Gm(M+m); not G(M+m) in denominator ( I cannot find how to reduce the Gm to be only G), I did it by hand and I came up with the same. Did I miss something or was there a typo or such?
Appreciate the help!
A typo. ω2r has units of acceleration, not force. Restarting with the equation for the center of mass,
[tex]F=m\omega^2 r_{cm} = \left(\frac{2\pi}{\tau}\right)^2\,\frac{Mm}{M+m}\,r[/tex]
[tex]\frac {GMm}{r^2} = \left(\frac{2\pi}{\tau}\right)^2\,\frac{Mm}{M+m}\,r[/tex]
Ughh, my bad. I read this when I was very tired and tried to answer the question too quicky (something I really shouldn't do!).
I saw NCStarGar's use of [itex]r[/itex] in the centripetal and gravitational force equations and assumed he was making the assumption that [itex]M>>m[/itex] and ignoring centre of mass issues. Of course had I taken on the significance of what he/she meant by "Newton's update" I would have realized that wasn't the intent...
Sorry NCStarGazer and thanks to D H for spotting this. Very embarrassed now!
  • · Replies 18 ·
  • · Replies 20 ·
