Kepler's problem in lagrangian formalism
  • Thread starter Thread starter quasar987
    Lagrangian
quasar987
In the statement of the problem, it is said that with an appropriate choice of units, the lagrangian for Kepler's problem can be written
L=\frac{1}{2}\mathbf{\dot{q}}^2+q^{-1}
A priori, what q is in terms of cartesian coordinates seems irrelevant because the problem only asks to show that the Runger-Lenz vector, defined by
A_k=\mathbf{\dot{q}}^2 q_k-\mathbf{q} \cdot \mathbf{\dot{q}}\dot{q_k}-q_k/q \ \ \ \ \ k=1,2,3
or, in vectorial notation,
\mathbf{A}=\mathbf{\dot{q}}\times (\mathbf{q}\times \mathbf{\dot{q}})-\mathbf{q}/q
is a constant of the motion associated (in the sense of Noether's thm) to a certain coordinate transformation.
But then the question asks, "Discuss the properties of this vector." and I'm kind of at a loss about what to say. I can't say much about its direction and its norm is ugly and uninsightful. So I figured if I knew what those q where in terms of cartesian coordinates, maybe I could make some sense out of the Runge-Lenz vector. So I try to get the lagrangian into the above form, right?
Ok, in cartesian, it is
L=\frac{m_1}{2}(\dot{x}_1^2+\dot{y}_1^2+\dot{z}_1^2)+\frac{m_2}{2}(\dot{x}_2^2+\dot{y}_2^2+\dot{z}_2^2)+\frac{Gm_1m_2}{\sqrt{(x_2-x_1)^2+(y_2-y_1)^2+(z_2-z_1)^2}}
We can choose the units of mass, length and time such that the lagrangian becomes
L=\frac{1}{2}(\dot{x}_1^2+\dot{x}_2^2+\dot{y}_1^2+\dot{y}_2^2+\dot{z}_1^2+\dot{z}_2^2)+\frac{1}{\sqrt{(x_2-x_1)^2+(y_2-y_1)^2+(z_2-z_1)^2}}
Compare this with where we want to go:
L_q=\frac{1}{2}(\dot{q}_1^2+\dot{q}_2^2+\dot{q}_3^2)+\frac{1}{\sqrt{q_1^2+q_2^2+q_3^3}}
Are there really maps q_i(x_1,y_1,z_1,x_2,y_2,z_2) that transform L into L_q ?!? :confused:
The q's are the generalized coordinates so if your generalized coordinates are the cartesian coordinates, then you should have the answer?
What?
The book says the lagrangian can be written like this:
Or, expanding the vectors into their components (i.e. the generalized coordinates),
L_q=\frac{1}{2}(\dot{q}_1^2+\dot{q}_2^2+\dot{q}_3^ 2)+\frac{1}{\sqrt{q_1^2+q_2^2+q_3^3}}
On the other hand, the cartesian lagrangian is
L=\frac{1}{2}(\dot{x}_1^2+\dot{x}_2^2+\dot{y}_1^2+ \dot{y}_2^2+\dot{z}_1^2+\dot{z}_2^2)+\frac{1}{\sqr t{(x_2-x_1)^2+(y_2-y_1)^2+(z_2-z_1)^2}}
Clearly the obvious q_1=(x_2-x_1), q_2=(y_2-y_1), q_3=(z_2-z_1) inspired by comparison of the "potential term" does not work for if we expand (\dot{q}_1^2+\dot{q}_2^2+\dot{q}_3^ 2) in terms of x, y, z, we do not get (\dot{x}_1^2+\dot{x}_2^2+\dot{y}_1^2+ \dot{y}_2^2+\dot{z}_1^2+\dot{z}_2^2).
So I ask in disbelief, is there really a coordinate transformation that allows one to write L as
P.S. Ideas about what to say about \mathbf{A} are of course welcome as well ! Besides the direction and the norm, what are interesting things to say about a vector?
I found it... q is actually just the ordinary position vector like Logarythmic pointed out (I think). So we are actually solving the Newton problem [particle in a 1/r potential] for a reduced mass µ (but with the units chosen to that µ=1). We can then set q=r1-r2 to get the solution to the actual Kepler problem.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
