Hi there,
I completely understand your frustration and confusion with this problem. It can be overwhelming to encounter a physics problem that seems complex and difficult to approach. However, with the right approach and understanding of the concepts involved, you can definitely solve this problem.
First, let's break down the given information and the question itself. We have two long, parallel wires hanging from a common axis with 4.00-cm-long cords. The wires have a mass per unit length of 1.50×10-2 kg/m and carry the same current in opposite directions. The question is asking for the current in each wire if the cords hang at an angle of 6-degrees with the vertical.
To solve this problem, we need to use the concept of magnetic fields and Ampere's law. Ampere's law states that the magnetic field created by a current-carrying wire is directly proportional to the current and inversely proportional to the distance from the wire. In this case, we have two wires with the same current, so we can focus on one wire to find the magnetic field at a certain distance.
To find the magnetic field at the cords' distance from the wire, we can use the formula B = μ0I/2πr, where B is the magnetic field, μ0 is the permeability of free space (a constant value of 4π×10-7 Tm/A), I is the current, and r is the distance from the wire. We can rearrange this formula to solve for the current, which gives us I = 2πrB/μ0.
Now, let's apply this formula to our problem. The distance from the wire to the cords is 4.00 cm, which is equivalent to 0.04 m. The angle between the cords and the vertical is 6 degrees, which means the distance from the wire to the cords is the hypotenuse of a right triangle with a base of 4.00 cm and an angle of 6 degrees. Using trigonometry, we can find that the distance from the wire to the cords is approximately 0.04 m.
Next, we need to find the magnetic field at this distance. We know that the wires have the same current in opposite directions, which means they create opposite magnetic fields. These magnetic fields will cancel each other out, leaving us with a net magnetic field of 0. To find the magnetic field of one wire
