How Do Killing Vectors Represent Spacetime Symmetries in Stephani's Relativity?
Pengwuino
In Stephani's "Relativity", section 33.3, equation (33.9), he has the Killing equations for cartesian coordinates as
\xi_{a,b}+\xi_{b,a}=0
From there he says upon differentiation, you can get the following three equations
\xi_{a,bc}+\xi_{b,ac}=0
\xi_{b,ca}+\xi_{c,ba}=0
\xi_{c,ab}+\xi_{a,cb}=0
Now, I'm not use to the ,; notation, but doesn't the first equation mean
\partial_b \xi_a + \partial_a \xi_b=0?
If so, I don't understand the other 3 equations then. If for example, the first one is suppose to be subsequent differentiation by \partial_c, then wouldn't it be\xi_{a,b,c}+\xi_{b,a,c}=0?
I think that it is supposed to be a second derivative, and the second comma is omitted. So:
\xi_{b,ca} = \partial_a(\partial_c\xi_b)
EDIT: If you assume that, then does it work?
As far as i can tell, no. He seems to be permuting the indices but I don't know what about the killing vector allows one to do that.
If you're working in a flat space without a torsion, then the partial derivatives commute when applied to any covector, be it Killing or not.
So from the Killing equation \xi_{(a,b)} = 0, differentiating it by x^c, one obtains succesively
\xi_{(a,b)c} = \xi_{(a,bc)} = 0 {} ,
thing which allows you, Stephani and everybody else to permute the indices in every of the 6 possible cases, without changing anything.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
