Kinematics, finding the displacement and comparing
To find the displacement from Bradford to Milton, measure the straight-line distance on a map, which represents the magnitude of the displacement. The direction of this displacement is indicated by the angle the displacement vector makes with the horizontal. When comparing this displacement to the distances traveled by the truck on different routes, it's important to consider that the total displacement is the vector sum of all individual displacements. The discussion highlights the importance of understanding both magnitude and direction in displacement calculations. Ultimately, the user resolved their confusion after revisiting the problem.
stephmaep
using a map, measure the displacement from Bradford to Milton. Compare the distances traveled to the for each route above with this displacement and explain the differences
Δd = vΔt
okay, so i may just being having a brain fart but. I've made my graphs for position-time graph for the truck traveling to deliver celery. I'm really just having a problem as to find the displacement on the map from Bradford to Milton. I don't really know how to approach it at this moment.
If you are measuring the displacement on a map from Bradford to Milton, the magnitude of the length of a straight line drawn between the 2 cities is the magnitude of the displacement. The angle that that displacemnt vector makes with the horizontal gives you the direction of the displacement. Neglecting curvature of the Earth. The vector sum of the separate displacements made by the truck also gives the total displacement.
i was indeed having a brain fart after walking away and coming back i figured it out thank you though :)
