Kinematics motion, projectile. This was an mcat problem. Thanks
The problem involves a firecracker that is propelled vertically and subsequently explodes into two fragments, each moving in different directions. The discussion centers around calculating the distance between the fragments when they hit the ground, incorporating concepts from kinematics and projectile motion.
  • Mixed
  • Participants explore the forces acting on the firecracker, including the launch force and gravitational force, and how these affect acceleration and velocity. There are attempts to calculate the time of flight for each fragment and the distances traveled both vertically and horizontally.
Some participants have provided guidance on determining the time it takes for the fragments to hit the ground, emphasizing that this depends solely on vertical motion. There are ongoing discussions about the calculations for vertical and horizontal distances, with participants questioning assumptions and the accuracy of their previous calculations.
Participants note discrepancies in their calculations, particularly regarding the time of flight and the effects of gravity. There is mention of the MCAT context, which may influence the values used for gravitational acceleration.
HumorMe81
A firecracker with mass 100g is propelled vertically with a launch force of 1.2N applied over 5s, after which it explodes into two 50g fragments. One fragment goes horizontally at 15m/s and the other goes to the right at angle 53 degrees with the horizontal at speed 25 m/s. find the distance between them once they hit the ground.
This is what I did:
Force up - Fg = ma
1.2N - 1N = .1kg a
a = 2m/s^2 upward
I used this info to calculate the speed right before the explosion:
V = Vi + at
V = 0 + 2m/s^2 * 5s= 10m/s
The distance elapsed in this time is:
Y = Vi*t + 1/2gt^2
Y = 1/2 (2m/s^2)*(5s)^2 = 25m
Since the problem says after the 5s the cracker explodes, I thought the fragment that goes left takes 5s to come back down and the distance it would travel is 75m. But I'm wrong. It travels 33m.
X = Vi*t + 0
The fragment moving to the right is at an angle so it has a horizontal and vertical components. Vx is 15m/s and Vy is 20m/s.
Can someone guide me please? Thanks
You need to determine the time it takes to hit the ground. What's the acceleration of any falling body?
Same thing for this one. How long does it take before it hits the ground.
Hint: The time it takes to hit the ground depends only on the vertical motion.
This is what I did:
Force up - Fg = ma
1.2N - 1N = .1kg a
a = 2m/s^2 upward
Your a is off by 10%.
V = Vi + at
Why compute this?
Y = Vi*t + 1/2gt^2
EDIT:
Correct this with the right a. The acceleration is a, not g as your formula states, but I see you did use a instead of g after all. So you're not off by much for Y.
I see doc al has put in so I'll leave it to him for the rest.
The MCAT may well use g = 10 m/s^2 for ease of calculation.
Ok, so i figured out what I was doing wrong. The fragment moving left travels a vertical distance of 25m. Right before it starts coming back down, its velocity at the highest point would be 0. I used this info to calculate time on the downward flight:
Y = Vi*t + 1/2gt^2
25 = 0 + 1/2(10m/s^2)*t^2
t = 2.2s
Now i can find the displacement of the fragment moving left:
X = Vi*t = 15m/s * 2.2s = 33m
For the fragment moving to the right, here's what I attempted:
After the explosion, vertical velocity is 20m/s and at the highest vertical distance it would be 0. The only acceleration it has during this segment is due to gravity downwards. I used this info to calculate the vertical height of the segment and time:
Vf = Vi + at
0 = 20m/s + (-10m/s^2)*t and t= 2s
Y= vi*t +1/2gt^2
Y = 20m/s *2s + 1/2 (-10m/s^2)(2s)^2
Y = 20m
The total vertical height is then 45m. Assuming velocity at the highest peak when fragment starts falling down to be 0m/s, i attempted to calculate the time of flight down:
Y = Vi*t + 1/2gt^2
-45m = 0 + 1/2(-10m/s^2)(t)^2
t turns out to be 3s and i used it to calculate horizontal displacement:
X = Vi*t = 15m/s * 3s = 45m
So the horizontal distance between the two fragments once they hit ground is 33m + 45m = 78m
However, that's not the right answer :(. What am I doing wrong?
For the particle going right you need the total time after the explosion, not just the time from the highest point.
Oh, so the time is 5s then. 2s after the explosion and 3s to come back down? If the total time is 5s then horizontal distance is 15m/s*5s = 75m and the total distance between the two fragments after they hit the ground is 33m+75m = 108m. That's the answer listed in the book.
  • · Replies 22 ·
