Kinematics problem, ball drop.
To determine the minimum horizontal velocity for a ball rolling off a staircase to hit the lowest step, the vertical motion must be analyzed using the equation s = ut + 1/2 at^2. The vertical drop of 0.3 meters requires calculating the time taken to fall, which is derived from the vertical motion equation. The correct approach involves ensuring the horizontal distance covered matches the required distance to avoid hitting the second step, leading to the conclusion that the initial horizontal speed must be calculated differently. The initial calculations were incorrect because they did not account for the necessary horizontal distance in relation to the vertical drop. Understanding the relationship between horizontal and vertical motion is crucial for solving this kinematics problem accurately.
AlchemistK
A staircase contains three steps each of 10 cm high and 20cm wide(refer attachment).What should be the minimum horizontal velocity if a ball rolling off the uppermost plane so as to hit directly the lowest plane?
s= u*t + 1/2 a*t^2
In the vertical motion,
s= u*t + 1/2 a*t^2
=> 0.3 = 0 + 1/2 * 10 * t^2
=>t= \sqrt{}6 /10 s
therefore, v=s/t => 2.45 m/s
Where did i go wrong? The given answer is 2 m/s and i don't believe that its an approximation.
I don't really see what you are doing. You start off by assuming that u, the initial vertical speed, is 0, which is true, and caluculate the time it will take to go down 0.3 meters. Finally, you calculate the average speed over that time. That was not what was asked. You are asked for the initial horizontal speed, ux, required so that the ball hits the lowest step. That is, you must find u such that the ball misses the second step. When the vertical drop is 0.2 meters, the horizontal motion must be at least 0.4 m. You have two equation: (1/2)at^2= 0.2, ux t= 0.4. Solve for ux.
Likes Atul Saswat
You did the last step wrong. You can't perform v=s/t because acceleration is there in the situation. But that's not for initial velocity asked in the question. Follow HallsofIvy advise.
Ahhh yes, i get it now, thank you.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
