Kinematics question centripedal acceleration and projectile motion
The problem involves a stone being swirled in a horizontal circle before the string breaks, causing it to fall and travel horizontally. The initial calculations for the time it takes to fall 1 meter were corrected from 0.672 seconds to 0.452 seconds. Using this corrected time, the necessary speed for the stone to travel 15 meters was calculated to be 22.32 m/s. The centripetal acceleration was then determined to be approximately 249.09 m/s². The overall approach to solving the problem was confirmed to be correct.
reb659
A stone is swirled in a horizontal circle 1.00m above the ground by means of a string 2.00m long. The string breaks, and the stone files off horizontally and strikes the ground 15.0m away. What was the centripetal acceleration of the stone before the string breaks?
kinematics equations
First I calculated how long it took for the stone to fall 1 meter using h=1/2*g*t^2 since initial velocity is zero because its only rotating horizontally. I got a time of .672 seconds. Then I determined the speed necessary for the stone to travel 15m in this .672 seconds using d=v*t. I got v=22.32 m/s. I plugged this speed back into the equation for centripedal acceleration, v^2/r, and got an Ac of 249.0912 m/s^2.
Is this correct?
I'd start by recalculating the time to fall.
Ugh, yeah, I miscalculated it. I got a new t=.452. Is the process I followed on this problem correct otherwise?
Yep.
Good luck.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
