Kinetic and potential energy in circular and rotational motion
tjackson3
Consider a bead of mass m that is confined to move on a circular hoop of radius r. The axis of symmetry of the hoop is horizontal, and the hoop is rotating about a vertical axis at a uniform rate \omega. Neglect friction and assume a constant gravitational acceleration of magnitude g. Let the angle \phi specify the position of the bead on the hoop, with \phi = 0 corresponding to the bead lying at the bottom of the hoop.
Derive the following Lagrangian:
L = T-V = \frac{1]{2}mr^2(\dot{\phi}^2 + \omega^2\sin^2\phi) + mgr\cos\phi
Since the Lagrangian doesn't depend explicitly on time, there is a conserved quantity for this system, E = \dot{\phi}\frac{\partial L}{\partial \dot{\phi}}. Compute E and show that it is constant. Is the constant the total energy of the system T+V?
Most relevant equations are there
I thought I computed the Lagrangian just fine. My logic was that there were two sources of kinetic energy: that of the bead moving in circular motion (mr^2\dot{\phi}^2/2) and that of the bead rotating. My thinking was that as the bead rotated, if it was at an angle \phi, then it was tracing a circle of radius \r\sin\phi, so its kinetic energy would be mr^2\omega^2\sin^2\phi/2.
I think the potential energy is purely gravitational. If h=0 corresponds to the height of the center of the hoop, then the potential energy is -mgr\cos\phi. This gives the correct Lagrangian.
However, it does not give the correct energy. When I compute E, it comes out to be 1/2 mr^2(\dot{\phi}^2 - \omega^2\sin^2\phi - mgr\sin\phi. That middle term has the wrong sign, but I can't figure out why. Moreover, this version of E is not conserved. The only conclusion I can reach is that somehow, what I took as rotational kinetic energy is actually potential energy, but that doesn't make sense. Any thoughts? Thank you!
I don't understand how your Rωsinθ is negative since Rsinθ is just the radial length from the axis of rotation to a point on the hoop
Potential NRG should be mgR(1-cosθ) because it is at a max when cosθ = 0 and that is perependicular to the axis of rotation and this is when your tangential velocity is a max
The lagrangian should be
.5mR2((dθ/dt)2 + ω2sin2θ) -mgR(1-cosθ)
and i know this is correct since i did this problem for an assignment a month ago
My R\sin\omega is positive. If you mean in the E computation, it's because in computing E, you subtract the Lagrangian, hence the negative sign.
As for the potential energy, I like yours much better than what I have; however, the first part of the assignment required matching the form shown in the OP, which didn't come through for some reason:
I'm also beginning to wonder if you would even expect that quantity E to be the total energy of the system, since I think there's also an effective potential in there somewhere
Its the pot that changes sign not E. what u were given is wrong. My prof gave us the textbook solution for the non inertial frame. And this question is an example in taylor.
Edit talking the derivative of anything will give u force not energy
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
