Calculating Initial Speed of Bullet After Collision with Spring-Mounted Block
To calculate the initial speed of a bullet after colliding with a spring-mounted block, apply conservation of momentum and energy principles. The bullet's kinetic energy is converted into elastic potential energy in the spring, represented by the equation 1/2kx^2. After determining the spring's energy, set it equal to the kinetic energy of the bullet and block combined post-collision. By using the momentum conservation equation, you can derive the initial speed of the bullet before the collision. This method effectively combines both energy and momentum conservation to find the solution.
PiRsq
Friction is negligible
A bullet traveling at speed v hits a wooden block which is attached to a spring with constant 200 N/m. After the impact if the spring compresses to a maximum of 0.1m and the mass of the bullet is 0.01kg and the mass of the block is 0.5kg find the initial speed of the bullet?
This was on my test today and I didn't get the answer, how would you go about doing this question?
Why not show us how you tried to solve it?
Hint: you'll need to use both conservation of momentum and conservation of energy.
I found the Elastic potential energy first to see the energy of the whole system by using:
1/2kx^2
Then since the kinetic energy must equal the total energy before the spring is stretch, I did:
1/2kx^2=1/2mv^2 and I solved for V
That's the speed of the block plus bullet---after the collision. Now find the speed of the bullet before the collision. (Re-read my previous hint.)
So momentum is conserved...
mv1+mv2=mv1'+mv2'
v1'=v2'=v'
v2=0
mv1=v'(m1+m2)
So I think to get v':
1/2kx^2=1/2mv^2
The energy came out to 1 Joule.
Equation I joule with kinetic energy :
2=(m1+m2)v^2
v=sqrt(2/m1+m2)
Now that I think equals v' right?
Subbing that back into the equation we can solve for v1
Is that somewhat right?
It is exactly right. Good job!
Thanks for the help Doc :smile: I just wish I thought of that during the test
