Kinetic Energy of a Rotating Bar
A thin, uniform bar weighing 12 kg and 2.00 m long rotates around one end, completing five rotations every three seconds. To find its kinetic energy, the bar is divided into infinitesimal segments, with the speed of each segment at distance r from the pivot calculated as V = (x*10*∏)/3. The kinetic energy of each segment is expressed as 0.5*(((x*10*∏)/3)^2)*dm, where dm is defined in terms of dx for integration. The discussion highlights the importance of correctly setting up the integration for calculating total kinetic energy, ultimately leading to a clearer understanding of the problem. The final realization simplifies the approach to solving the kinetic energy of the rotating bar.
student34
A thin and uniform bar has a length of 2.00 m and weighs 12.0 kg. It is rotating from one end on a pivot 5 times every three seconds. What is its kinetic energy?
This is its hint: break the bar up into infinitesimal segments of mass dm and integrate to add up the kinetic energies of all of these segments.
v = d/t = 20∏m/3s
Ek = 0.5*m*v^2
∫(12kg - 0kg)0.5*v^2dm
∫(12kg - 0kg)0.5*v^2dm = (0.5(20∏/3)^3)/3 x 12 = 18374J
But I am way off because the answer is 877J
Have you seen the hint?
What is the speed of an element dm at distance r from the pivot?
No, the hint is just in words.
V = (x*10*∏)/3
This seems like more advanced calculus than we are expected to know because we usually have to integrate functions that have only one variable, and it's usually obvious in the function. Or am I not seeing an easier way.
No, you have only one variable, x.
You can write dm in terms of dx. Imagine the small mass element dm as a thin disk of thickness dx. The bar being uniform, of mass m and length L,
dm=(m/L)dx
dm=(m/L)dx
Oh great, I finally get it, thanks!
