What is the Mass of Your Faster Running Friend?
The discussion centers on a physics problem involving kinetic energy and mass during a race between two friends. The initial setup indicates both friends have the same kinetic energy, but one friend runs faster. The user attempts to calculate the mass of the faster friend using the kinetic energy formula but encounters errors in their calculations. Key corrections involve adjusting the relative velocities and ensuring the velocity term is squared in the formula. After applying the suggested corrections, the user successfully finds the correct answer.
a18c18
You run a race with your friend. At first you each have the same kinetic energy, but then you find that she is beating you. When you increase your speed by 21%, you are running at the same speed she is. If your mass is 77 kg, what is her mass?
K=1/2mv^2
K(initial me)=1/2*77*.79v
K(initial friend)=1/2*mass*v
1/2*77*.79v=1/2*mass*v
the v's cancel out so the mass should be 30.415/.5 or 60.83 but this is not the right answer. Does anyone know what I did wrong?
You started out with the right idea for setting up the problem, but there are a few errors.
1. Check the math for the relative velocities. If you started out 21% slower than your friend, you were not going 0.79Vfriend.
Try using Vfriend = 1.21Vme.
2. Check the formula you used in your step 3. Velocity should be squared. Remember to calculate the entire term (1.21V)2.
Once you make these changes, you should get the correct answer.
Okay i got it. Thank you so much!
