Kinetic Friction and Ropes and Pulleys
The discussion revolves around a physics problem involving two blocks connected by a rope over a pulley, with Block A on a horizontal table and Block B hanging. Block A has a weight of 4.91N and Block B has a weight of 2.94N, and both blocks move at a constant speed. The key equations involve the relationship between tension, weight, and kinetic friction, with the need to find the coefficient of kinetic friction for Block A. One participant questions the necessity of finding the coefficient for Block B unless it is sliding, emphasizing that the forces acting on Block A must balance due to the constant speed. The solution involves equating tension to friction and normal force to gravitational force for Block A to determine the coefficient of friction.
dizkoducky
Block A, on a horizontal table, has a weight of 4.91N is attached to a rope, that goes over a pulley, attached to Block B, that has a weight of 2.94N. Once block B is set into downward motion, it descends at a constant speed. Assume that the mass and friction of the pulley are negligible. Need to find the kinetic friction coeffecient for Block A and Block B.
Kinetic Friction = (coeffecient of Kf)(Normal Force) in the opposite direction
Tension - Weight = 0
Therefore, Tension = Weight
I have drawn FBDs for both blocks. I understand the tension & normal force of the two, individually. I am having trouble connecting the tension to the normal force to find the coeffecient.
Thanks!
starr
I don't understand why you need to find the coefficient of friction on Block B unless Block B is sliding along something as it falls.
As for your question, let's look at Block A. Along the horizontal axis you have Tension pulling the block and friction resisting the block's motion. These two forces will be equal since the blocks are moving at a constant speed. In the vertical axis you have the normal force pushing up on Block A and Fg pushing down. Again these two forces will be equal.
So we have:
(for Block A)
Tension = Ff
Normal force = Fg
Once you have Normal force and Ff you can solve for the coefficient of Friction.But like I said, if there is friction acting on block B the problem will be a little different. (Specifically the Tension will change)
